I'm after the weight of it etc as I had the idea to turn mine into a sort of roadgoing tribute to it
cheers in advance
toxo wrote:I can't help you too much with the specific car but there are some awesome engine shots here from the JGTC Supra, which was also 3S-GTE powered and entered into the GT300 category:
http://www.v-eight.com/tech_forum/viewt ... f=35&t=594
http://www.v-eight.com/tech_forum/viewt ... f=35&t=592
Absolutely awesome.
toxo wrote:Well that's specifically the TRD JGTC entry, so I'm sure there were plenty of other Supras running all kinds of setups.Didn't one of the TOM's ones run a 3S-GTE as well though?
The most famous and successful Toyota Race engine- the 503E was used in Toyota's Triumphant Championship seasons in IMSA GTO/ GTP, Pikes Peak, Le Mans, and in the mid-90s Japan Touring Cup Championship.
It is important to note that the 16 valve cylinder head layout from the 152E engine and the T block crankshaft saddle design were used as design base for this ultimate Toyota 4 cylinder Turbocharged race engine.
The 503E represented the most powerful 4 cylinders in competition history developing over 1000HP in qualifying tune, 800HP for sprint races, and 600 for endurance events.
IMPRESSIVE.
