foxy-stoat wrote:Not sure if this is much help to you, but just took my drive shafts off this weekend to drop the engine, and after undoing all the bolts, got the shaft out but managed to mess up the ball races at the gearbox end.![]()
Did this before on my last MR2 and its a"ball ache" to get them all back in properly.
I am not sure if you will be able to see if the 6 ball bearings are seated correctly with the gator on, but you might be able to feel if 1 or 2 of the bearings have dropped out from the cage.
