I want to get a water temp gauge installed so I can keep a vigilant eye on temperatures.
I was going to install one using one of these: http://cgi.ebay.co.uk/38mm-WATER-PIPE-H ... 3efcf24ec5
Are these okay to use on the MR2? Also, what ID are the rad hoses?
Cheers,
Jamie
I don't see why it wouldn't work. Finding a place to put it though might be a different matter. Let me know what you come up with as I've considered the same thing but never got anywhere with it.
Safe bet on the ID of the pip would be to measure the OD and then take off about 6mm, then see where you're at with what sizes are on the market.
rad hose wouldnt measure engine coolant temp as if the thermostat is closed it wont be getting flow.
why do you need a gauge more accurate than the std one? have you modified the car in such a way that you have sensitive cooling issues?
Jim Galbally wrote:rad hose wouldnt measure engine coolant temp as if the thermostat is closed it wont be getting flow.
I was having some overheating issues, I want to get a much more accurate reading to see if my temps are fluctuating.
robbrookes5 wrote:i have one of these fitted to my trd dials its fitted in the engine bay to a pipe near the air filter if that helps
