Have you checked your brake fluid level? Might be a bit low, and when you nail it it sloshes the fluid back, so dropping it below the warning sensor.
Not sure if its the same on MR2's, but in other cars I've had the fluid warning light is the same as the handbrake light.
.if the fluid was low and you went hard round a corner the light would come on.
Worth checking anyhow
