[All] [Generic] J, JJ, ", mm's, offsets, widebodys and confusion
Jimbob
Post by Jimbob »
Right, I'm a bit confused. As I understand it.............
- J and JJ are rim profiles made to a specific standard
- A rim width is measured in " to the extreme outside faces
- An offset is the difference between the wheel centre line and hub face
So my wheels are 254mm wide measuring from the inside edge of the rim to the outside edge of the rim. So I guess 10" wide The centre of the rim has JJ stamped on it. So 10JJ.
The distance from the rear face of the wheel to the hub face is about 135mm. So I worked out the offset as..........
254 / 2 = 127mm, and 135mm-127mm = +8.0
I have also measured the rim depth from the edge of the outer rim face to the surface which the spoke faces bolt onto. Thats 88mm.
Now I went onto a website to find some info out about the Volk GT-U and found the following link....................
http://www.upgrademotoring.com/wheels/gt-u.htm
So my 17x10JJ +8.0 are on there where?
The reason I want to know is I am looking at new wheel options. Also interested in what people have if they have widebody's.
James
JeffD
Re: [All] [Generic] J, JJ, ", mm's, offsets, widebodys and confusion
Post by JeffD »
Bit of useful reading:
Wheel/tyre calculator specificly for MR2
http://mr2.gordaen.com/wt_calc.php
General wheel/tyre calculator
http://www.rims-n-tires.com/info_specs.jsp
http://www.carbibles.com/tyre_bible_pg4.html
The "perfect" wheel/tyre combination for a widebody as per the brochure is:
17x7JJ +13 215/40 R17
17x8.5JJ +7 245/40 R17
Rahzel
Post by Rahzel »
What wheels you looking at getting mate?
This is a guys car off the US forums
The Meister S1 front is 18x8.5 -12 with 215/35/18 and rear is 19x10.5 -23 with 235/35/19
JeffD
Post by JeffD »
That car is off the "hella flush" thread on www.MR2OC.COM and those wheels protude beyond the tires and the bodywork if you look at the other pics - not a good look IMO
Rahzel
Post by Rahzel »
gives him an idea what is possible with offsets though. personally if i had a trd i would want to fit the widest wheel i could :mrgreen: at least a 10". 8.5" is a bit weak.
its all a matter of opinion and taste, granted im not one for the stretched look myself raise the car a bit and fit some propper sized rubber :thumleft:
JeffD
Post by JeffD »
Ive PM'd you some weak wheel pics LOL
fearless
Post by fearless »
Rahzel wrote:What wheels you looking at getting mate?
wow im in love what a car i love those rims what a beast. :thumleft: :thumleft: :thumleft:
Jimbob
Post by Jimbob »
Meister S1 3 pieces is what I am going to get, didn't really want to let on :-$
Seen that one it runs daft offsets thats why they stick out, he's on
Front : 18x8.5 -12 215/35/18.
Rear : 19x10.5 -23 235/35/19
I'm running 10's now and you could easily get 11's on without hassle on my car, but I am trying to work out my exact wheel spec as a baseline to calculate which way to go.
I want my wheels to sit about 10mm more into the arch, I have a good 30+mm clearance inside the wheel arch to the strut (coilovers). That will allow slightly wider tyres, i'm only on 235's now. They grip well but break every now and again, and in 3rd thats nervy :pale:
Going crazy big just sacrifices handling for looks. 10J is fine. 8.5J is pretty small as I run 9J on the front now. However there are clearance issues on 17's with 215's. The tyres catch on full lock when parking and sit well out in the arch, but my car is low. I will probably lift the front a tad and get 225's up front and 275 on the back.
I'll take a look at PM's, cheers Jeff.
Jimbob
Post by Jimbob »
Its quite interesting the TRD site recommends 8.5 +7 :-k
If i'm running 10 + 9 that makes my rear aches approx 21mm wider? Theres no way I could run any more offset as it would be inline with the arch and clash on bumps. Maybe I should measure the outside width of the car?
JeffD
Post by JeffD »
Arches should be 30mm wider each side than stock so car is 60mmm wider overall:
Jimbob
Post by Jimbob »
Hmmm, makes for interesting reading.
I am now lost in thw world of offsets, seem slike I can't get what I want to fit.
