Threads split, jonb- you might want to go back to the racing driver thread and put a new post up to say that you won't be attending?
There have been some problems with some pattern water pumps experienced on two brutal for the V6 engines.
I'm not sure whether they're even the same manufacturer that Camskill use
(I would expect CS to use Blueprint who's V6 pumps are fine).
I'm not sure whether this has any bearing on water pump construction for the 3S-GTE either to be honest.
It just suggests to me that there are some pattern manufacters who perhaps aren't paying as much attention as they should be.
I did put a genuine pump on mine when it needed changing.
In my eyes a water pump is a pretty important part and shouldn't be skimped on.
I would find someone who's got a Toyota trade discount if you can, my pump was
£88 inc VAT IIRC.
I'd order it for you but then we'd have to arrange delivery and the like and that will push the cost back up again!
