I have read and re read the threads on the AM2 fuse and don't have an answer.
Problem: Key turned to on and the fans come on and lights on dash light up. Turn to fire and the AM2 fuse blows.
can someone give me a list of things i should check in order?
[Mk2] [NA] AM2 fuse problem ... again. Please help!
Re: [Mk2] [NA] AM2 fuse problem ... again. Please help!
things I have checked:
12V getting to the AM2 fuse
12v getting to the IGN relay
Dash lights dim when key turned to start position
car has been sat for quite a while
Please help
Please help
Try replacing ign. main relay.
Sound like its shorting.
Well after much head scratching it turns out it was down to the immobiliser system which looks like it was put in by a blind man. Loom under the dash was hacked to bits and a short in the rear fuse box was probably the final cause. IUmmobiliser system removed and car started first time!!! Sounds a bit ropey but that the next thing to fix!
Ahhh wasnt far off with the short then just wrong bit suggested.
