hi guys,
i crashed my rev1 mk2 turbo , now am having the engine from it put in to a N/A body . i know i must swap the engine with gearbox, suspension, brakes and the ECU etc... but is there anything else i should know about. any suggestions will be appreciated. cheers
mk2 turbo- N/A rev1 engine swap
Re: mk2 turbo- N/A rev1 engine swap
fuel pump...rear anti roll bar...rear hubs...er....cant think of anything else.
yes i can.....turbo engine mounts,but you prob knew that already.
engine swap
cheers mate!!
iv gotta walbro fuel pump so thats getting changed neway, and am thinking of going for new or uprated engine mounts. if you remember nething else please do let me know. cheers
if you do get new engine mounts your old turbo mounts will come in useful over on www.twobrutal.co.uk ,the lads there will snap them up,help put another mk1 turbo on the road.
gtr2 wrote:hi guys,
Engine wiring loom will have to be changed, just up to the passenger footwell though, plug+play job! You should also change the brake master cylinder due to upgrade of the brakes! Your best changing the fuel pump when the engine is out and not after like me.................nightmare!!
Your prob putting it into a G-Limited import. so dont know if this applys as I had a UK N/A, but I had to change the gear linkages and the gearlever & base. Also best doing while engine is out.
Can't think of anything else that hasn't been mentioned.
engine swap
thanks alot guys. am transfering the engine in to a uk spec N/A so i guess that will apply to me. thanks again. please keep the info coming in.
Engine from n/a
Noticed your post about transplant, was wondering if the n/a engine was good [-o< cos if it is I would be interested to know how much you would want for it?
irishdavemr2 wrote:Engine wiring loom will have to be changed, just up to the passenger footwell though, plug+play job!
Don't be fooled into believing this - it's rarely a plug and play job and even if you try it and it works, there will be systems connected to each other that shouldn't be but don't seem to show any apparent ill effects.
Make sure you pin everything out first and do the job properly.
Rogue
Just re-read your post and realised your target kit is a UK model. Definitely not a plug and play swap.
Rogue
Rogue
