David21 wrote:So i think what you need to do is set all the gears with an X and set the start duty above 0% then it should know not to use the learn gear funtion......me thinks
i've allready tried this... nothing change...
is anybody there know this avc-r perfectly ?
I've seen many many post about the AVC-r, may be it could be usefull to create something about this system in the knowledge base of the forum...
So for now...i'm still lost... more ideas ?
