[Mk2] [Turbo] intercooler as a rad
Odd one but is there any reason why you cant use the stock inter cooler as a rad for the ST205 charge cooler? I know the pipe diameter would need to be massively reduced.
Re: [Mk2] [Turbo] intercooler as a rad
It's totally possible. Master JJ on here used a stock IC as a rad for his first 205CC setup IIRC.
It's to small plus the heat soak from the engine bay would make it very inefficient, it's quite possible, just not very practical...
yep JJ used it and found it to be wanting
thanks guys,
found this http://www.imoc.co.uk/forums/viewtopic. ... cooler+rad
Think I go down the bigger intercooler route now
the std intercooler has bad properties when used as a water heat exchanger.....
