Hi Guys - hope you can help me.
Im looking to replace one of the pistons one my Rev 3 Turbo (its fitted with a rev 5 motor)
The Piston has the two numbers engraved on the crown:
080904-3
9055D050
I have looked in the toyota EPC - and I cant find any reference to these numbers. Im begining to suspect that the engine is fitted with a set of forged pistons....
...Or it may be that someone has acces to a later version of the Toyota EPC and that this is a new number....
[All] [Generic] Piston Identification
Re: [All] [Generic] Piston Identification
Do a google search on the second number and it comes up with 86.5mm wossner forged pistons for the 3SGTE.
Check out the link below.
http://www.performanceenginecomponents. ... asp?id=204
Cheers Lewis - I did have a search on eBay but didnt find the Connection to Wossner. It does look like my motor is fitted with Woosner Pistons... like this:
http://www.performanceenginecomponents. ... 0turbo.jpg
Will have to call them and see if they will sell a single piston!
Brian
Brian
you have broke a wossner piston?
A broken inlet valve has made a small mark in the crown of piston 4 ( I have removed the head and got a replacement unit).
Its a small mark but if I dont replace it I wont ever trust the motor again, The piston set is pretty new (there isnt even any carbon on them) so I dont want to replace the lot - Im hoping I can order just the one...
Brian
Brian
was gonna say, probably one of the best pistons out there, not heard of one breaking before
send a pic to wossner and ask their opinion on the mark?
