[Mk2] [Turbo] Will these wheels fit?
Dan88
Post by Dan88 »
Im about to purchase some super advan sa3r's, theyre 17's with 5 stud 114.3 fitment. Currently on a skyline, will they fit my mr2?
cantfindausername
Re: [Mk2] [Turbo] Will these wheels fit?
Post by cantfindausername »
stud pattern yes. you might need different spigot rings, and also the offset might be out.
***RIP Car13 ***
*** Now in an Evo ***
Dan88
Post by Dan88 »
what are my parameters for offset on the mr2? he's going to tell me the offset when theyre off the car, so i will know for sure then.
are spigot rings easy to purchase? can just use the normal plastic ones you get surely?
cantfindausername
Not sure. So many topics on here about offset. Think mine are +35 or +38. Depends on wheel width etc as to what will fit and what will look right. Fitting doesn't mean looking right though.
Some places will do spigot rings off the shelf. As long as you have a 60.1mm center bore then you should be alright. Not sure what will be on the skyline.
***RIP Car13 ***
nikaiyo
Post by nikaiyo »
You will deffo need spigot rings for SA3R's mate, the centre bore is WAY off for the MR2. 75mm springs to mind, but i dont think that can be right lol
I got mine from performance_wheels on ebay, £10 for 4 plastic ones, had no probs with them :thumleft:
Dan88
Post by Dan88 »
awesome mate, as long as they will fit il be happy! £300 for a set of SA3R's with no marks and with centre caps, im pretty happy!!
if you could find out what size spigot rings that would be absolutely awesome mate
Dan88
Post by Dan88 »
Ive just been told that the sizes of the wheels are as follows:
9J 38 rear
and
8J 35 front
do they seem ok for the MR2? i thought they might be a bit wide, but in terms of width and offset, would people say they would fit?
sjm1984
Post by sjm1984 »
they'll fit perfect
i got the same on mine :)
tarmac terrorist
Post by tarmac terrorist »
will look good these are mine
rear: 9jj 255/35/18
front: 8.5jj 215/45/17
