On the front toe arm, the two conical bushes have a steel tube that goes through the centre, I guess to protect the bush, and also so you can't over-crush them when you tighten up the 22mm Nut to torque.
In the Super flex suspension kit for the front toe arm it includes a new steel tube for this.
In the rear trailing arm, at the point where it goes through the lower arm, those two bushes as stock have a steel tube through the middle.
I guess my questions are two fold:
Can anyone confirm that when you fit the superflex bushes you do or do not use a steel centre tube on the rear arm?
Has anyone had problems after fitting these bushes one way or another?
I can still retro-fit them, but I'd like to know what is
