Spare Wheel Mounting...
Has anyone used any alternative methods of securing their spare wheel in the frunk? I've just fitted 15" wheels and have a matching spare I want to carry but because the wheel/tyre combo is slightly bigger than the stock the standard bolt/clamp is too short and is also slightly offset now so can't be used. I did think about just using a luggage strap or something to secure the whole thing but think it will look a bit naff and diy?
Securing spare wheel
You may find that you can get longer bolts off other cars such as a Mk3 MR2 or a Celica perhaps. A good Toyota breakers is what you need. Regarding the centre hole alignment you may find that one of the wheel stud holes can be used
Re: Spare Wheel Mounting...
Yeh thanks for that, I'd been thinking along those lines too. The other option I've thought about is using a 15" space saver spare from a MK3 MR2 which will obviously be a lot thinner.
I've got a mk3 roadster alloy in my frunk and it fits perfectly with no alteration or change of bolt
SuperRedMR2 wrote:I've got a mk3 roadster alloy in my frunk and it fits perfectly with no alteration or change of bolt
Yeh but the problem is mine aren't MK3 wheels plus I also wanted the face of the wheel showing outwards in the frunk (rather than backwards) which is why the bolt is far too short! Anyway I've sorted it today by using some threaded bar and making my own longer bolt and a dome nut on the end for neatness.
Thanks to everyone for all the replies
oh sorry, read it wrong
One thing to watch out for is the height of the top of the tyre - I once put a 15" wheel with 205/50 tyres in my frunk and it pushed the centre of the bonnet up a bit
MartG wrote:One thing to watch out for is the height of the top of the tyre - I once put a 15" wheel with 205/50 tyres in my frunk and it pushed the centre of the bonnet up a bit
Thanks for the warning, I'll check for that!
