My rear centre panel is scratched and I need to do something about it. How do I go about removing the silver MR2 badge? Is this just stuck on? If removed, I assume it won't just stick back on again.
hey mate...ive just removed mine...with dental floss get a good length between your fingers (no comments lol!) then just run it behind the badge using the floss to cut the adhesive off (kind of like you are sawing the badge off)
If you are careful you could possibly reapply the badges afterwards but would need more adhesive. I just used a bit of thinners to clean the panel up, and hey presto, debadged! (10 min job)
HTH
Darren
fishing line does the same thing aswell, also heating badge up with hairdryer and wedging a credit card behind gets it off without scratching paint or doing damage .
Fill a sink with very hot water and leave the panel to soak for 5 mins then you can carefully peel it off. Paint your panel then apply a little bit of contact adhesive to the back of the badge (which should still be quite sticky) then reapply.
