![pale :pale:](./images/smilies/icon_pale.gif)
Andytoyota wrote:wastegate getting stuck is what i'd bet on, possibly the fitting is at fault?
Andytoyota wrote:If its not boosting much or at all then the boost gauge isn't going to go up either! The boost gauge uses a vacuum pipe from the manifold to get a reading i believe so no sensor involved as such.
^Trickster^ wrote:Is the actuator arm still attached to the wastegate? If not it will just be flapping open and you wont produce boost.
If the garage did it take it back, tell them to sort it.
Graeme
Graeme
Steve-O 2007 wrote:Are your heater controls on or off? The Only sounds I hear when I turn Ign on is the heater fans starting to blow and the power steering.
Moo wrote:Other than the heater fans the only other blowing noise I can think of is the rad or intercooler fans.Where was the blowing nosie coming from, front or back? If the engine bay temp sensor was disconnected the intercooler fan would have been on all the time.
Maybe this was the case and the garage noticed and reconnected the sensor? Just a wild stab in the dark.
lee.w wrote:Moo wrote:Other than the heater fans the only other blowing noise I can think of is the rad or intercooler fans.Where was the blowing nosie coming from, front or back? If the engine bay temp sensor was disconnected the intercooler fan would have been on all the time.
coming from the back I think, you could be right.
I just remember when you put the ignition on 3 you hear a loud blowing noise but only when you turn the ignition on and now it's stopped since I got it back
, so is that a good thing
Moo wrote:
Check to see if the engine bay temp sesnor is connected.If it is then unplug it.
This will make the intercooler fan spin the moment the ignition is on.
Is this the noise you heard before?
Generally people disconnect this sensor to intentionally have the fan running all the time to keep the engine bay cooler or because the temp sensor has failed.
Moo wrote:The temp sensor is bolted to the underside of the engine bay cover, in the middle toward the bottom edge.From memory it's a cylindrical piece of black plastic that tapers to a point.
Its exactly the same sensor as plugs into the airbox.
