Timing using PFC
Ja99a
Timing using PFC
Post by Ja99a »
Anyone know how to set my base ignition timing using a Apexi PFC?
I am running a AP engineering REV2 unit.
Also how do I turn of the ignition timing control so I get static RPM's?
Help
TheRoadWarrior
Re: Timing using PFC
Post by TheRoadWarrior »
I think you would check/set it in the same way as with a standard ecu, the only issue is as you say getting static rpms. So timing gun, down the side of the cam cover to see the marks on the crank pully, then turn the dizzy till you're at the correct setting (Is it 10degs btdc?)
edit; my bad, looks like it is different with the pfc. .sorry!
Ja99a
help me
Post by Ja99a »
Yes but I still need to know how to set the damn thing.
LOL HELP ME>...
So far I have plummed for setting the dizzy in about the middle of the adjustment and hope that the pfc will correct as it goes...
