How much gearbox oil?
Dean_82
Post by Dean_82 »
In a rev3 turbo?
Also what oil is recommended? MT90 is not a option sadly as car is in having a clutch change now. I'm guessing they will have some at the garage its in. Its a Renault garage. The same oil they put in the Megane turbos an option?
Matt_Cooper
Re: How much gearbox oil?
Post by Matt_Cooper »
You fill the gearbox with oil until it begins to run out the filler plug on the back of the box.
StevenstonWullie
Post by StevenstonWullie »
i used 4 quarts of mt90 in my rev3 tubby....
T-Bar Turbo
Post by T-Bar Turbo »
3.8 litres for a rev 3 box with lsd and 4.2 without
hth
Baker
Post by Baker »
for some reason the rev 3 LSD boxes seem to take less than 3 litres. mystery!
toxo
Post by toxo »
75w-90 synthetic gear oil is the stuff you want. The diff in a turbo box is sealed so you're not lubricating that, you're just lubing the gears. It's generally between 3.5l and 4l depending how much of the old stuff you drain out (ie how long you leave it dripping and how hot it was when you opened it!).
oilman
IMOC Affiliated Company
Post by oilman »
Yep 75w-90, loads are popular Redline, Motul, Silkolene etc http://www.opieoils.co.uk/c-673-75w-90.aspx
Guy
Use the code IMR2OCUK and get 10% Club Discount
oilman's website: http://www.opieoils.co.uk/ register for news and offers
email: [email protected]
phone: 01209 202944
