[Mk2] [Turbo] Weak Ignition maybe - reduced gap from 0.8 to 0.6
b4ss
Post by b4ss »
Hi,
I have replaced coil pack/HT Leads/rotor/dizzy, all with Toyota parts.
New plugs gapped to 0.8 - car hesitates under full boost, but otherwise seems fine.
New plugs gapped to 0.6 - car runs perfectly all the way to full boost.
I don't really know where to start, maybe earthing points?
For info the car has new AEM 320lph fuel pump, and I have had the injectors tested for flow rate and spray pattern and ultrasonically cleaned.
Any ideas, or should i just leave them at 0.6?
Thanks,
Tony
androo007
Re: [Mk2] [Turbo] Weak Ignition maybe - reduced gap from 0.8 to 0.6
Post by androo007 »
did you check your ignitor? they crack and cause all sorts of missfire issues under boost.
b4ss
Post by b4ss »
androo007 wrote:did you check your ignitor? they crack and cause all sorts of missfire issues under boost.
Interesting I wasn't aware of these...
I see MR2Ben only has NA ones :(
https://www.mr2-ben.co.uk/products/565
Thanks,
T
Juliuswws
Post by Juliuswws »
Thanks,
T
Hi Tony,
Hope you are well!
The igniter is the same for REV3+ turbo and N/A (except beams)
The part number for it 89621-16020 and 89621-26010 <-both the same thing.
Many corollas, rav4 and others using it so easy to get used. If you want to get new, that's a different story.
I have a spare one I can borrow it if you want. Got it from fleebay for £10 as a spare.
The igniter using the chassis ground so make sure it has good connection to its bracket. If it wouldn't be grounded, you get a code 14 and no start.
Hang on, just thinking now I had similar issue few years ago and it was the tiny little hose going to the MAP sensor. Once I replaced it, there were no more hesitation.
Should this not work, you can check if the igniter has good ground with a multimeter. While working with the multimeter, you might as well check the 3 temperature sensors for the ECU. I know which wires to check at the ECU connector, just ask me if it comes down to that.
Cheers,
Julius
b4ss
Post by b4ss »
Thanks,
T
Hi Tony,
Hope you are well!
Cheers,
Julius
Hi Julius - all good here - hope u are keeping well :)
Nice one for the tips will check them all, I managed to track down a new igniter :)
Thanks for tips will check those tonight...
Do you have you plugs gapped to 0.8 now and all good?
Thanks,
T
Juliuswws
Post by Juliuswws »
Glad to hear!
Yep, mine are gapped at 0.8.
I use the iridium variant bkr7eix or something like that.
Are you on copper or some precious metal?
Cheers,
Julius
b4ss
Post by b4ss »
Juliuswws wrote:Glad to hear!
Cheers,
Julius
Using platinum also tried copper neither worked at 0.8..
Did you end up changing you igniter in the end?
T
Juliuswws
Post by Juliuswws »
Cheers,
Julius
T
No, there was no need to change that. Still healthy @ 250k
Did you check the lines to the MAP sensor?
I had too much time in the recent weeks, just replaced most hoses in the engine bay:)
But that's for another topic
Return to “Electrical”
