[Mk2] [Turbo] rev 3 ecu from rev 1
paddymr2
Post by paddymr2 »
Hi people,
I wanted to see is this possible, as my current car a rev 2 that has a rev 1 ecu in it 17321 the car should have 17380, (ive no idea why someone would do that and probably a rev1 loom which is causing a lot of issues.
i wanted to see whats involved in upgrading?
What i need to buy
What the cost might be
Can i do it being a complete novice.
Steve
platmatt8
Re: [Mk2] [Turbo] rev 3 ecu from rev 1
Post by platmatt8 »
It's probably at this late stage in the MR2's life not worth trying to upgrade to a Rev3 ecu.
You will need a MAF sensor, loom, ecu but I forget the exact things now. It's not an easy swap and you will gain little from it.
Sorry
Return to “Electrical”
