https://www.tuningdevelopments.uk/produ ... cts_id=275
Apparently supports 600bhp. I'd have to make up some pretty mad pipework to get to my daft side feed inlet. I have never really heard much about tuning developments and I can't see any real world info about this intercooler.
[Mk2] [Turbo] Top mount intercooler
Re: [Mk2] [Turbo] Top mount intercooler
For that money probley a re branded Chinese one tbh... would work but on a hot day and driving hard it would get heat soak I would image..
Would a Boot mount set up a better option for you?
That is just a £99 Chinese Freddy intercooler, but they want £180 for it...
The wheel already exists, don't tie yourself up in knots trying to reinvent it. Either re-do the chargcooler set up (this is what I'd do) or fit a boot mount intercooler
- Ryan S
- IMOC Moderator
I thought the exact same thing. Why they are saying it supports 600bhp is beyond me.
Yeah you're right rob. I think for now I'll sort the CC system. It did work well when it worked.
I may go bootmount Rich. I did want to keep the boot but it's not a deal breaker.
- Ryan S
- IMOC Moderator
sorry to keep bleating on guys. I would like to add a reservoir tank to my CC setup but I thought the reservoir had to be HIGHER than the CC core. However in this video that is definitely not the case.
https://www.youtube.com/watch?v=634Qwkf__hk
Can anybody shed some light on this? I have the space to do exactly the same with mine as in the video.
No my swirl pot for the CC system isn't higher than the cc core.... the pump has to be the lower than the swirl pot to feed the pump... air will always be forced to the swirl pot but as long as the pump pick up the coolant it doesn't mater where the level of the cc and the swirl pot are as it will always flow
hope it helps
cheers rich
hope it helps
cheers rich
- Ryan S
- IMOC Moderator
Ah, so i guess the pressure from the pump fills the core before the water being pumped back into the reservoir? I'm gonna add a tank in that case. I have plenty room from it.
