[Mk2] [Turbo] UK car with Rev3 turbo conversion, coilovers settings.
BALDYMONSTER
Post by BALDYMONSTER »
Just got a set of these:
https://www.vipmotorsport.co.uk/Toyota- ... -Coilovers
Has anyone else fitted these and if so could someone give me a rough front and rear measurement for the the individual units? I want to keep the car -40mm all round.
Just being a bit lazy if I'm being honest and it would save a bit of fanning around with adjusting them while they're on the car to some degree that's all.
Aditonally, if anyone has these same units fitted what setting on the stiffness adjustment do you use for the road?
Running 7" by 17" wheels all round and fronts 215/40/17, rears 235/40/17 with 10 mm spacers on the rear.
Just thought I'd see if anyone had a similar set up.
Thanks.
