Shane's rev 5 turbo,mapped 569 BHP, For Sale
shane34
Premium Member
Post by shane34 »
So I've never done a build thread before, although I've had rev 3 turbos for about 12 years, I've just never been interested in engine tweaks or modding, the last one I owned for 5 years didn't even get a mbc fitted and I never de restricted it. I don't tend to drive fast it just nice to know it's there when the time is right. I think the greatest feeling is starting the engine the sound of it just makes me smile. Oh and definitely it's looks.
So due to a change in what type of mr2 I own i thinks about time i started one. Right now I do not plan on doing any power enhancing mods as it's fast enough for my once a month drive. Lol. But watch this space i respect the car but it does not scare me so who knows :)
So the story behind the car, Some may know that I bought a car from julian(top guy) with everything pretty much complete ready to drive at a very brutal 2.1 bar boost. What a world of difference 1 bar extra makes in performance compared to my old mr2.
I have to emphasise the great work by julian in picking that parts and accessories that has formed the car to what it is. I'll be honest most of the items are new to me, im learning about each part as I go. Which is the fun part for me.
So my plans for the car. Basically remove any rust from sub frames arms etc and re paint. Ill also Replace any items that are not as new. Cancer bar for example.
So the spec list. I'll have to copy this from the for sale thread as there is to much to remember
> LinkG4 Plug and play
> Link 4Bar map sensor
> Garrett g25-660 .92ar- inc screamer Pipe�
> TIAL Wastegate 44mm
> TTE WRC Group A Corolla Manifold � Inconel
> Racer X fuel rail
> ID dynamics1050cc injectors�
> Aeromotive FPR�
> Goodridge braided fuel hoses�
> Goodridge fuel connectors�
> Walbro 255lts/hr in-tank performance fuel pump�
> Custom Inlet Manifold�
> Edelbrock 75mm Mustang Throttle Body�
> 3� custom Inlet Manifold pipework fabrication�
> Blue Samco Hosing�
> Custom 4� Induction Pipe and Filter�
> ACL Duraglide Big End Bearing set�
> AEM Adjustable Cam Gears�
> Wossner 86mm forged pistons�
> APR Uprated Head Stud Kit�
> ARP Main Stud Set�
> Eagle Conrods�
> Piper 262in/264ex Cams�
> Piper TOYOTA 3SGE / 3SGTE single valve spring set�
> Sbits Head gasket kit�
> Speed-Source Polyurethane Engine Mounts�
> HKS SSQV�
> 4 Way EGT sensors installed into the TTE exhaust manifold.
> Magnecor KV85 2.5mm competition Ignition leads.
> AEM FAILSAFE AFR WIDEBAND AIR / FUEL RATIO AND BOOST IN ONE GAUGE # 30-4900
> 3 way boost solenoid
Exhaust�
Complete custom top mount exhaust.
> 80mm ID Dowpipe with Screamer pipe set up
> 3.5" rolled Tips
> active driver side Exit pipe. Undecided if i will go boost activated or electronic solenoid.
Clutch/Transmission�
> Reconditioned Rev3+ gearbox
> TRD "LSD" Limited Slip Differential
> OS Giken R2CD Twin Plate Clutch (TY141-BH6)�
> OS Giken Dampened Twin Plate w/Floating Centre Hub�
> CRW Axle cages Stage 2 Axle Cage Upgrade�
Cooling�
> Custom 3� pipework fabricated for Boot Mount Intercooler�
> Custom Boot Mount Intercooler system�
> 11" Spal fans x 2�
> Aquamist WI System HFS2 � v3 (PWM Valve system�
> Water/Meth tank for Aquamist WI System�
Wheels
> BBS LM 17" gold refurbished and in marked
Chassis/Suspension
Meistar R coilovers
Toms frunk cross member
Toms engine bay cross member
Toms lower front cross member
Brakes
> supra front brake discs. 300zx callipers
> RX8 Rear Discs
> Rear Braided and front Brake Hoses�
Exterior�
> Neo's Design GReddy lip spoiler�
> Genuine - "Greddy" Gracer side skirts
> Tinted Rear Windows
> Phoenix power type engine lid
> USA red rear triangles
> Rear meshed center panel ( more exhaust now)
> fiberglass bonnet
Interior�
> REV 5 Leather Interior
> Recaro Tomcat limited edition 2 of 250 ever made
Mods done
Coilovers fitted
Lazer alignment
Refurbished exhaust can and flex
Defi EGT gauge. Need a decent location
Toms front rear and lower chassis bars
Completed jobs
New Oring for speed sencor
New oring for distibuter cap
Drilled and retapped old fixing for under trays
Drilled and retapped from light covers
Fixed the subframe mounting bolt
Painted and fetteled inlet manifold
Painted subframe Anti roll bars pertrol tank few other brackets
Repaired the PP engine lid. fixing had pulled out
Installl carbon fiber bonned catchs and screen washers
Fitted new front fog lights
Fitted Recaors to MR2 rails
2019
Aquamist kit is now been upgraded to version 3, dash control, flow sensor, tank level sensor.
4 way egt to canbus via ECu for logging
New afr guage installed which no monitors the afr for engine cut.
Exhaust valve boost activated.
New water pump
New cambelt and tensioner
New spark plugs
New HT race leads
New coil pack
New rotor arm
New thermostat
New coolant.
New oil and filter.
New throttle position sensor
New fast acting AIT sensor.
Mapped.
Priorities items to fix or buy
New injectors
New fabrication up and coming
New twin exhaust will go into detail later. Should be interesting
New throttle body electronic and electronic foot peddle fensport will set this up with the link G4
Possible new dual plenum.
Possible turbo, quite fancy a Borg Warner with a titanium wheel, undecided on size.
Then re mapping. Probably all in time for winter haha!
shane34
Premium Member
Re: Shane's rev 5 turbo,mapped 569 BHP, For Sale
Post by shane34 »
Gone of the days of laying down. I can happily sit upright and do stuff.
A bit of cleaning a painting. Also drill and tapping the old sheered undertrays bolts.
One of my oil leaks is in The below image
My second oil leak seems to be the near the distribution cap area where it bolts to the head.
Probably a better view from the top, this was underneath without the subframe in place etc.
JLW
Post by JLW »
This Car sounds like its running a very nice spec mate, looking forward to seeing pics.
where are you in Kent ?
GeorgeL
Post by GeorgeL »
Brilliant car you have bought yourself there buddy...
A lot of the components surrounding the engine were from one of my old builds (2 years a go) and I watched this car being built up (apart from the engine block itself) at YVS performance where it was put together.
It was a pleasure to have been able to see this being built up back then and it will be a pleasure to watch as you develop it yourself and make the changes you are setting out to do.
I hope you enjoy it buddy :) lovely car indeed!
'98 Rev5 Turbo (GEO 1S)
TOTB13 RWD 1/4mile 1st place
TOTB14 RWD 1/4mile 3rd place (Misfiring)
TOTB15 RWD 1/4mile 2nd place (HG Failure)
TOTB16 RWD 1/4mile 1st place
shane34
Premium Member
Post by shane34 »
Bit of an update, pictures to follow
Had a few small issues nothing to really worry about, typical 2 life!
the idea was to find the oil leak, the smell of petrol and To investigate the lack of braking assist!
5 months later, I've found 2 oil leaks, spread sensor O ring and the distributer O ring, can not source the petrol smell as yet. The braking I've not looked at yet!
Did a few other bits mind you
While the sub frame was off this got a fresh coat of black paint the anti roll bar and track rods got a nice coating of gold.
The missus painted the petrol tank front subframe and the radiator housing which was a bonus.
Fitted the toms front lower brace. Will paint at some point
Fitting new cancer bars, not sure why!
Fixed the subframe main fixing point, the chassis bolt was stripped.
Polished the intake pipes.
painted the inlet manifold, and filed out the burrs on the inside from the vacuum lines
Removed any oil residue, contact cleaner works wonders.
In the process of fitting the Tomcat recaros to Oem runners, with a standard seatbelt mounting point. 1 complete, drivers side of coarse!
Items to do/fit
Fix the Phoenix power engine lid the fixing point has pulled through
Fit the Carbon fiber bonnet carbon areo catches
Front fog lights
Tom front cross member
Toms rear cross member
Fixing the braking issue/ possibly upgrade to 4 pot fronts. Need more info on this 1st!
Pop up to fensport for a map tweak,😜
Then to make some shows and give Santapod a go!
Next project for the car after the above will be a Major exhaust change, need to do some measuring and research!
juliankv73
Post by juliankv73 »
Can't wait to see pics of my old girl!
Your certainly giving her lots of love and attention and soon with teething issues sorted and map tweak, will be a finely sorted 2. :twisted:
Tubed in buddy :thumleft:
shane34
Premium Member
Post by shane34 »
Ordered this
MGL Avionics TC-1 4-Channel Digital Thermocouple
the plan is to monitor each manifold pipe. will need to mod the Inconel, there are 2 ports already blocked on this, im sure they will be simple enough to do.
Awesome motor. Missed this thread when you posted it back in August last year. Tuned in. :thumleft:
shane34
Premium Member
Post by shane34 »
Bit of an update
all back together. 1st outing of the garage in 5months
need new headlight housings. anyone got any or know where to buy? Toyota?
Perfect. :thumleft:
shane34
Premium Member
Post by shane34 »
Bit of an update. Pictures and video to follow.
I decided to upgrade change a few parts.
I didn't like the exhaust that was on the car, quite loud and although it looked good it wasn't what I wanted. This system had a total of 9 short radius or cut bends it wasn't pretty. the bore was around 73mm. I wanted a more free flowing system, I also I didn't want to put the heat of the exhaust into the flow of the boot mount inter cooler chute this along with The screamer pipe basically discharged into it aswell.
So I'm pretty much here now, took a lot of work and I mean a lot. I've decided to go over the engine and out through the back above the boot mount between the lights.
The new system has 2 long radius bends and 1 x 45 degree, the pipe is of a 80MM bore, 2mm thick. I have made a split silencer with each side equal with the idea on making some active valves. The hole system is wrapped with ceramic wool rated to 2000 degrees, ive then completely Titanuim wrapped over the top. I can touch the exhaust all the way to the 1st bend next to the turbo housing.
The screamer pipe is side exit now, and it's amazing to hear with the window open, the last setup was twice as long and had around 6 bends, the new set up has 2 bends and 1 x 45 degree. I didn't penetrate the mesh when exiting the after a few tests it penetrated itself, the exhaust gasses melted the aluminium fine mesh.ill be replacing with stainless and some hi temp black paint.
My next plan will be to move the inter cooler below the boot with a bigger chute maybe a 3rd fan, Now I have no exhaust I have plenty of room to make so guiding fins into the direction of the inter cooler and then through the boot.
I have also installed my 4 way manifold temp sensors into the inconel manifold, early days yet but it seems to be working out ok I need to check and calibrate them by switching sensors around to confirm that they are reading the Same temps.
I've started the boot lid mod with the NA engine louvers in just above the exhaust silencer. Undecided how to do this yet. I have a perfect fitment with my cut outs, I'm not sure welding it would be the best way due to heat warping. Fiber glass and filler? No idea yet may speak with a body shop? Anyone got a recommendation in Kent?
I need to make the pannel between the lights this will be mesh and metal opposed to plastic.
Going forward
Thinking about bigger injectors and a motect rotoary switch to adjust he boost settings, then I'm pretty much done! Famous last works.
shane34
Premium Member
Post by shane34 »
Will take some engine bay shot tomorrow.
I like the idea of that exhaust mate. Any pics from inside the boot? Thanks :thumleft:
Post by Martin F »
craig wrote:I like the idea of that exhaust mate. Any pics from inside the boot? Thanks :thumleft:
Ditto :thumleft:
Looks good, did you ever get the power run you were wanting ? I pressume this is just a road going car or do you have plans to track/drag her ?
SeanSw20
Post by SeanSw20 »
Really like this
shane34
Premium Member
Post by shane34 »
Thanks guys
Need to update this at some point. Car is running really well. Will be at japfest unfortunately not managed to get onto the stand.
No power run yet. Maybe soon tho
juliankv73
juliankv73
shane34 wrote:Got an itch for a change from the mr2 nothing wrong with it just fancy something else.
:shock: just seen your post on killerferrets thread, what's happening fella? :-k
Any updates,... :thumleft:
Also interested in updates on this :thumleft:
2barGee
Post by 2barGee »
craig wrote:Also interested in updates on this :thumleft:
and a video please......... :whistle:
