5sgte with beams crank pulley & 5s sensor motec
V6? V8? TDI? Discussion and technical advice for engine transplants inc. 5SFE & 5SGTE builds. Not for N/A to Turbo, or Rev1/2 to 3+ conversions.
Project and build threads welcome.
rikstergt4
Post by rikstergt4 »
Hi everyone I'm looking for the motec ref/sync parameters for the 5sgte 1zz cop's setup with beams crank pulley & 5s crank sensor + hall cam sensor.
If anyone can help please post up your ref/sync motec page for setup reference it will be a great help.
ashley
Re: 5sgte with beams crank pulley & 5s sensor motec
Post by ashley »
This is what I've used to initially get the engine running
rikstergt4
Thanks ashley that's a great help I'm trying to save some money & install & setup the motec enough to get it running & hopefully run the engine in before I take it for mapping but it's proving a lot harder than I anticipated.
rikstergt4
Did you go with the 1zz dwell setting from the motec site
ashley
Post by ashley »
No - we used a current probe and scope to measure it- the only data I could find on the Motec site was for 2ZZ coils. That said- it wasn't that different, and when I compared to data from two other people (thanks Mikey on here, and Ryan G)- we were all in the same ball park.
Return to “MR2 Engine Swaps”
