I'm pretty sure this applys to both PS3 and 360 users. Ive been trying to set up my computer as a media server using vista and WM11 but my PS3 just wont detect it.
The media server comes up in my network folder on vista but everytime i go into WM11 i get the error message.....
"Media sharing is currently disabled, either because the sharing service is not running or your firewall settings have changed. To restart sharing, you must first confirm your sharing settings."
Anyone been able to set up a media server with vista?
Vista Media Server
Re: Vista Media Server
Haven't set it up on a ps3 but the sharing settings for wmp11 are in TOOLS-->OPTIONS-->LIBRARY-->CONFIGURE SHARING
Due to vista though it aint working, i'm using tversity instead now.
un1eash wrote:Due to vista though it aint working, i'm using tversity instead now.
probably coded into it vista somewhere not to work with the ps3
Probably...works perfectly with the 360...
Did you go into WMP11 -> Library -> Media Sharing and then click on "Allow" to the PS3/360?
After that you need to put all the files you want to share in your Shared folder....in either Shared Video, Shared Music or Shared Pictures...should work fine then....
Although thats only for 360....if its similar you might find that useful....
