Steve's 1.5 SE build thread
Goto page Previous  1, 2, 3, 4, 5, 6, 7  Next
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 Engine Swaps
Author Message
PW@Woodsport
IMOC Affiliated Company
PostPosted: Wed Jan 02, 2008 6:04 pm    Post subject: Reply with quote Reply with quote including images
cheers G,its really no bother to be honest,im just copying across the same build thread from TB.
Well today was day 1 of the conversion,and there was a lot to do! starting with the removal of the mk2 turbo engine from its donor....this one looks dirty and manky but it purrs sweetly with no oil consumption and zero turbo play,it also comes with an LSD equipped box so a result there for steve.Needless to say this engine will look very different before it goes into steves car
A few hours later and it was out,it was lowered onto my engine dolly and then pulled clear of the car...
We then pulled the petrol tank out as well to get the turbo fuel pump out,we are going to need this for steves build.... and steves sc pump will be used in petes build.
With that done and all necessary parts stripped off the mk2 i pushed it outside and drove steves SC onto the lift....
Heres his SC engine just before i removed it...
A few hours later and that too was on the floor,i dont think ive ever done as much in one day!
So both engines have been removed from their respective homes,tomorrow sees the SC engine mounts removed from the chassis,the point of no return i call it! and the turbo engine partially stripped and degreased.
Forgot to say if you want to follow the build live go to....
tv.woodsport.org
username:woodsport
password:tv
click camera A either activeX or java depending what your pc has.
_________________
Back to top
User is offline
Rosssco
PostPosted: Wed Jan 02, 2008 6:12 pm    Post subject: Reply with quote Reply with quote including images
Paul,
Would be an interesting time to get a really big set of scales and find out the exact difference in weight between a complete 3S-GTE with 'box and 4A-GZE with 'box.... [Laughing]
Back to top
User is offline
PW@Woodsport
PostPosted: Wed Jan 02, 2008 6:24 pm    Post subject: Reply with quote Reply with quote including images
thats a great idea...where can i get scales from before tomorrow? i wonder how high bathroom scales go?
Back to top
User is offline
Rosssco
PostPosted: Wed Jan 02, 2008 6:38 pm    Post subject: Reply with quote Reply with quote including images
Not high enough I suspect mate, unless maybe they are US-spec... [Laughing]
Back to top
User is offline
cartledge_uk
1986 Toyota MR2 Mk1 SC
PostPosted: Wed Jan 02, 2008 7:15 pm    Post subject: Reply with quote Reply with quote including images
Wouldnt work, all bathroom scales read lower than real value due to female fiddling
Back to top
User is offline
andyj
1987 Toyota MR2 Mk1 SC
PostPosted: Wed Jan 02, 2008 8:37 pm    Post subject: Reply with quote Reply with quote including images
Paul, fascinating stuff. I'll be looking in at the tv site.
So out of interest why was the donor car scrapped? Is it difficult to find donor vehicles and where to they come from? Do you source donor cars for the customer?
Andy
Back to top
User is offline
cartledge_uk
PostPosted: Wed Jan 02, 2008 9:29 pm    Post subject: Reply with quote Reply with quote including images
Andy
Most come from here clicky me or any breakers STB, BOK, GTS chris.. etc etc.
Cars are broken for various reasons, most tubbys seem to crash, especially round winter times.
Back to top
User is offline
Tony jinxy froude
1989 Toyota MR2 Mk1b
PostPosted: Wed Jan 02, 2008 9:51 pm    Post subject: Reply with quote Reply with quote including images
Its what the MK2's were made for......... as engine donors for the MK1 [Mr. Green] [Mr. Green] [Mr. Green] , Jinxy
Back to top
User is offline
Mk1 Turbo Powered Steve
PostPosted: Thu Jan 03, 2008 4:24 am    Post subject: Reply with quote Reply with quote including images
Andy
Hi Andy, the donor car wasn't scrapped it was still on the road, the bloke i bought it from drove it to Pauls.
It was great yesterday, i was watching my engine being taken out on Pauls tv cam.
Back to top
User is offline
System-G
1985 Toyota MR2 Mk1a
PostPosted: Thu Jan 03, 2008 7:59 am    Post subject: Reply with quote Reply with quote including images
Paul / Steve, what is happening with the GZE? Is it being used for Pete's build? Any special plans?
Back to top
User is offline
cartledge_uk
PostPosted: Thu Jan 03, 2008 10:19 am    Post subject: Reply with quote Reply with quote including images
Its going its petes car, there will be another swap thread for it to hopefully.
Back to top
User is offline
PW@Woodsport
PostPosted: Thu Jan 03, 2008 6:13 pm    Post subject: Reply with quote Reply with quote including images
indeed there will tim,i dont mind doing that.
Right today i dropped out the fuel tank....
This was to install the mk2 turbo fuel pump and also get the SC pump out for petes car.... here is the turbo pump fitted into the mk1 carrier,plug n play.
next job was to chop the battery tray out and also get rid of the engine mounts..... here is the NS mount ground off and battery tray gone...
And the OS mount ground off....
While i was in a grinding mood the rear boot wall got doctored as well,this is for manifold clearance and intercooler pipe routing.You dont need to chop the firewall but it lets the engine sit 1" further back which straightens the driveshaft angle and keeps the turbo away from the evap lines on the front bulkhead
This hole gets braced and panelled in before i respray the engine bay.
Next job was to fit my mk1 turbo mount jig,this one was made off my original 1.5 back in 2002 i think.... it bolts onto spare holes in the engine bay and places the mounts exactly where they need to be,without this jig it takes approx 2 days of faffing around dummy fitting the engine to get the driveshaft endfloat correct and tacking plates in... thats how the very first 1.5 wa built along with a few others.A much more professional version of this jig is available for loan for TB big members.
Next job was to cut out the mount plates out of 5mm steel.For this we lay cardboard templates (these templates are also available on TB in the downloads section) out on the steel and spray over them.....
then i used my plasma cutter to cut them out.
These are then marked and drilled to fit the jig holes and welded onto the chassis....
Then the jig is unbolted and removed from the bay,its job is done.... and both mounts are seam welded and given top plates for strength....
the completed NS mount
the completed OS mount
Once the rear wall is welded all welds will be seam sealed and the whole engine bay resprayed.
Back to top
User is offline
PostPosted: Fri Jan 04, 2008 3:51 pm    Post subject: Reply with quote Reply with quote including images
It's looking good Paul, i like these daily updates!!
Back to top
User is offline
Tony jinxy froude
PostPosted: Fri Jan 04, 2008 4:12 pm    Post subject: Reply with quote Reply with quote including images
Great job as always mate [thumleft] Thanks for sharing this with IMOC, it may persuade a few others to go for the swap too [thumleft] , Jinxy
Last edited by Tony jinxy froude on Fri Jan 04, 2008 5:57 pm; edited 1 time in total
Back to top
User is offline
PW@Woodsport
PostPosted: Fri Jan 04, 2008 5:49 pm    Post subject: Reply with quote Reply with quote including images
well i dont need the work but if it encourages a few more home builds that would be great
Back to top
User is offline
Tony jinxy froude
PostPosted: Fri Jan 04, 2008 6:00 pm    Post subject: Reply with quote Reply with quote including images
Yeah ive seen that, you work too bloody hard as it is mate !! [thumleft]
Jinx
Back to top
User is offline
That's why i have gone with the man that know's what he is doing!
It's great you have taken on my car. I know it will be the best quality!
Back to top
User is offline
PW@Woodsport
PostPosted: Fri Jan 04, 2008 7:01 pm    Post subject: Reply with quote Reply with quote including images
i do my best steve!
today i fabricated the rear boot access panel supports,these add a bit of strength to the rear firewall and provide a face for the access panel to be bolted back on...
then its a matter of bridging the sides in with steel plate....
and the other side gets a smaller plate....
this is because the intercooler pipes will exit the engine bay just above that panel.
next job was to dummy fit the intercooler,we partition off the right corner of the boot and dedicate it to cooling,much better than stuck in the mk2 engine bay i think.Vents can be added above or below or in the side quarter in future if steve wants more.I made supports that hold the IC exactly where it needs to be....
Next the coilpack and injector resistor pack are dummy fitted...i needed to weld bolts onto the walls to hold these priort to painting....
Next all welded joins are seam sealed...
And with the engine bay masked it got two coats of cellulose primer followed by a groundcoat of mica blue....
This is just the first mica blue ground coat to help with coverage,hence why its patchy,it will get 3 or 4 more coats of 8E4 on monday and then clearcoat laquered.
Back to top
User is offline
pkmr2
2005 Toyota MR2 Mk3 Roadster
PostPosted: Sat Jan 05, 2008 12:21 am    Post subject: Reply with quote Reply with quote including images
Amazing progress paul you really don't hang about! [Applause]
Won't be long b4 we can say goodbye to my well known smokey na lump guys. Nomore Stinky Pete!!!!!!!!!
Back to top
User is offline
PW@Woodsport
PostPosted: Sat Jan 05, 2008 10:51 am    Post subject: Reply with quote Reply with quote including images
cheers,pics look a bit crap at the moment but its early days... thats just the first groundcoat of paint,it will look 100% better and the correct colour once i get several coats of midnight blue on there and laquered... then it will be like a new engine bay.
Lots more to come.
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 Engine Swaps All times are GMT
Page 2 of 7
Jump to:
