Anyone running the rev 3 power fc on a rev2? If so how much did it cost in total, including all replacement sensors, rewiring etc. Also how much did it cost to map it when it was fitted?
thanks
Apexi power fc on rev2
Re: Apexi power fc on rev2
I have a rev 2 FC which required just about everything the rev 3 one does;
Power FC, datalogit, IAT sensor and GM map sensor - 600 quid (second hand)
Rev 3 ignitor - cost to feed JJ
The rewiring is fairly straight forward for the rev 3 to rev 2 car.
Small turbos - they're not big and they're not clever!
Just say NO to small turbos!
cool. thanks m8. Do you know anything about Link engine managment? I'm torn between that and the power fc. The link seems to do everything the power fc does, plus it can map water injection. Any thoughts on these two??
thanks
Dean
BTW Wolfkatz got a replacement set of fuel rail bolts to me in 4 days! Thinking i may now need some 850cc injectors thou
thanks
Dean
Thinking i may now need some 850cc injectors though
The list will never end dean !
Don't forget about a fuel pressure regulator, higher flowing fuel pump !
850s at stock pressure should see quite a few ponies Dean Do change the fuel pump though.
Link ... they do a Link Plus unit or something which is their best one. Not sure if it can control your aircon though
hi m8,
yeah got a walbro pump and Aeromotive FPR so i'm all set on the fueling front. I'll make some enquiries about the aircon on the link plus. thanks for the info
Could be worth trying talking to Thor - I believe they have mapped an MR2 with a LINK
what about rev 1s though? everyone seems to list for rev 2 and rev 3 on but never mention rev1. what are the diffs in wiring between 1 and 2?
when having my unichip fitted i was told some early rev1's had different boost control wiring and boost could not be 'sorted' by ECU means, didn't matter for me as my engines a rev2, so there are differences, at least for 'early' cars.
'97 mk1 Mazda Eunos Turbo track car with 260bhp/ton - soon more as Chris Wilsons going to build me an engine over the winter ) .
