Could the width of the forum be sorted, cos unless your browser is about 1000pxs wide you need to scroll to the right to see things\read threads.
Also on the profile section the width of the mod sections are restricted to 150.
<td class="catLeft" align="center"><span class="gen"><b>Engine Mods:</b></span></td>
<tr>
<td width="150" align="left"><span class="gen"></td>
</tr>
I assume this is an oversight and easily fixed?
Forum real estate
Re: Forum real estate
Aidy,
Yeah profile stuff was just a mistake.
As for the size needing to be larger...are you talking about when someone posts a long link or just viewing anything.
I view it at 1600x1200 on 23" lcd and looks OK to me...
Just up your resolution.
It doesn't matter what you're looking at, the site's width is a fixed minimum of about 1000 or so. If you're taking a sneaky peek at work it's a pain having to scroll the browser.
Right I will see if I can do anything about it....although my pure html skills are not amazing. I find the php and DB backend easier to deal with!!!
Am I losing the plot or was the profile text issue resolved a few days ago?
I'm sure I looked at mine a day or so after this thread and it was OK, just been back in today and it's all squashed again.....
Aidy wrote:It doesn't matter what you're looking at, the site's width is a fixed minimum of about 1000 or so. If you're taking a sneaky peek at work it's a pain having to scroll the browser.
Should be fixed now.
Broken again?
michael wrote:Broken again?
The overall width or the profile stuff....to be honest since the profile stuff is disappearing once the garage is completed I will not be bothering to fix it. If it is the overall stuff I will look at it.
The width of the fields seems to have gone back to being narrow again in profiles.
michael wrote:The width of the fields seems to have gone back to being narrow again in profiles.
Michael,
I am about two weeks away from having a finished garage code to upload. Think I will leave it and fingers crossed the garage will prove to be a hit. Have you tried it since I added image uploading...still lots to do but really starting to show what it will work like now.
I got your email re the new updates but you didn't give the URL to the test forum and it's slipped my mind... I'll get on the case though
michael wrote:I got your email re the new updates but you didn't give the URL to the test forum and it's slipped my mind... I'll get on the case though
http://www.13awingfield.com/imoc/forums/garage.php
Thanks..
Decided it was worth fixing....so should all be OK in the profile section now. Fingers crossed that will be the last change before the garage hits the big time.
