Oil Light
phaeton
Oil Light
Post by phaeton »
1st question do Rev 2 Turbo's have one (oil light that is), 2nd question if so where on dashboard is it & 3rd question where is the sender on the engine cheers
Merlin
Re: Oil Light
Post by Merlin »
The oil sender presure sender is on the same side of the distributa , but near the turbo just under the rocker cover oil pipe to the inlet pipe, its prety big and with one cable
you can just about see it on here right in the middle at the bottom between the strut brace and the big hose comming out of rocker cover
phaeton
Re: Oil Light
Post by phaeton »
Thanks Merlin now I know where to look I can start to investigate, you can't tell me where on the dash it should be could you, it might obnly be a bulb.
Merlin
Re: Oil Light
Post by Merlin »
here you go fresh from the cold out doors!!!!!
its the one that looks like an oil can
regards
Rob
phaeton
Re: Oil Light
Post by phaeton »
Thank you very much
Merlin
Re: Oil Light
Post by Merlin »
not a problem, i also have a spare oil presure sender, if ur in need of one
regards
Rob
phaeton
Re: Oil Light
Post by phaeton »
Rob, tested circuit today it is the sender I have PM'd you.
Return to “Electrical”
