Cylinder head refitting
nutter
Post by nutter »
Well i'm i'm getting there! the cylinder head is back together and on the car
now it's question time!
q1. The arp studs have a hexagon cut out at one end. Does this mean they have to be fitted a certain way round?
q2. ARP supply washers with their kit. Do i not use the washers that sit in the cut outs in the cylinder head? Or do i just put these ARP washers on top? Sounds like a stupid question i know but i'm tired and can't think straight!
thanks
paul_h
Re: Cylinder head refitting
Post by paul_h »
nutter wrote:Well i'm i'm getting there! the cylinder head is back together and on the car
thanks
the hexagon cutout os so you can screw them in with an allenkey if they are a bit tight.
you use the new washers instead of the old ones, they should be the same size.
paul
nutter
Post by nutter »
great thanks paul
