[Mk2] [Turbo] UK car with revision 3 full conversion. Engine management light coming on?
Author Message
BALDYMONSTER
PostPosted: Thu Jul 25, 2019 7:07 pm    Post subject: [Mk2] [Turbo] UK car with revision 3 full conversion. Engine management light coming on? Reply with quote Reply with quote including images
Engine management light comes on, I get indicated full boost on both my displays but feels like half the power.
Switch off ignition and all good then a few minutes later engine management light on and same thing, feels like half power but indicating I’m getting the boost I’ve selected.
Car isles fine, no sudden stuttering or cutting out or similar. Just engine management light comes on and put my foot down blitz dial solenoid boost controller and omori dash boost gauge indicate the boost I’ve set it to but feels like I’m back in a non turbo MR2.
Any ideas off the top of people’s heads?
Back to top
User is offline
SonicSW20
Premium Member
1997 Toyota MR2 Mk2 NA Rev4
PostPosted: Thu Jul 25, 2019 7:53 pm    Post subject: Reply with quote Reply with quote including images
Have you checked the error codes?
Back to top
User is offline
mrhappy62
PostPosted: Thu Jul 25, 2019 7:59 pm    Post subject: Reply with quote Reply with quote including images
[d'oh!] just told him paper clip test on the OC
Back to top
User is offline
BALDYMONSTER
No as I don’t know how to.
It’s going back to the garage tomorrow to get the reader put on it.
Back to top
User is offline
SonicSW20
Premium Member
PostPosted: Thu Jul 25, 2019 8:03 pm    Post subject: Reply with quote Reply with quote including images
https://www.mr2oc.co.uk/know-your-2/mk2.html?view=kb&kbartid=162
Only takes a minute.
Back to top
User is offline
BALDYMONSTER
PostPosted: Thu Jul 25, 2019 8:05 pm    Post subject: Reply with quote Reply with quote including images
Thank you.
Back to top
User is offline
BALDYMONSTER
PostPosted: Tue Jul 30, 2019 4:17 pm    Post subject: Reply with quote Reply with quote including images
Fault code 52.
Back to top
User is offline
SonicSW20
Premium Member
PostPosted: Tue Jul 30, 2019 4:39 pm    Post subject: Reply with quote Reply with quote including images
No knock sensor signal and the ECU is in safe mode.
Problem could be knock sensor itself or a wiring issue.
If it is the knock sensor then you need to ascertain why the knock sensor failed.
Back to top
User is offline
BALDYMONSTER
PostPosted: Tue Jul 30, 2019 4:41 pm    Post subject: Reply with quote Reply with quote including images
Are the knock sensors the same on both turbo and non turbo blocks?
It wouldn’t surprise me if it’s just bad wiring for obvious reasons.
I’ll get it checked out with the MOT.
Back to top
User is offline
Ryan S
PostPosted: Tue Jul 30, 2019 6:47 pm    Post subject: Reply with quote Reply with quote including images
They often fail when they detect knock. Too much boost and or cheap fuel.
_________________
www.straitupstudios.co.uk
Back to top
User is offline
BALDYMONSTER
PostPosted: Tue Jul 30, 2019 8:57 pm    Post subject: Reply with quote Reply with quote including images
It’s most likely the cheap fuel I put in it and the tank being really low.
Like I said I always use V Power.
I don’t run much boost either.
Back to top
User is offline
androo007
PostPosted: Wed Jul 31, 2019 7:33 pm    Post subject: Reply with quote Reply with quote including images
Next stop: ringland failure.
Back to top
User is offline
BALDYMONSTER
PostPosted: Mon Aug 26, 2019 11:18 am    Post subject: Reply with quote Reply with quote including images
Are the knock sensors the same on turbo and non turbo?
Sensor and wiring all seems ok so next stop new sensor.
Back to top
User is offline
Display posts from previous:
Page 1 of 1
Jump to:
