[Mk2] [Turbo] Paint bubbling on sills, no rust?
b4ss
Post by b4ss »
Hi,
Has anyone notice their paint blistering/bubbling on their sills?
I burst some of the bubbles and water came out..
When I ground off the blistering the metal was perfect underneath no rust?
Any ideas?
Thanks,
Tony
Re: [Mk2] [Turbo] Paint bubbling on sills, no rust?
I'd be taking off the interior rear trims and inspecting the inner sill cavities, and also check whether the sponges have been removed.
tubbychat3
Post by tubbychat3 »
Craig.. Can you elaborate on this please?
How do I inspect my inner sills?
Which sponges need removing please
tubbychat3 wrote:Craig.. Can you elaborate on this please?
No problem. It's the rear plastic covers with the speaker grills in them. They need removing. *might* need to remove the seat belt also, can't remember! To gain access to the inner sill cavity.
There is a sound deadening sponge that Toyota put in there to reduce noise, but this gets damp and sinks into the inner sill and rusts it from the inside out. So if your aren't removed, they need removing!
Once you access to the inner sills, you can shine a light in there and assess the degree of corrosion etc.
Hope that helps.
tubbychat3
Fantastic, thank you
