I've got myself a chinesium special upgrade side mount intercooler..
Would anyone know of anyone selling a fan shroud to fit the aftermarket intercooler?
I understand GTS Crhis used to sell these but all the posts I can find are quite old..
I'll be purchasing a SPAL fan but would like a shroud to fit also..
Turbo aftermarket fan shroud
Re: Turbo aftermarket fan shroud
I see them on Prime Driven, is that the only option folks?
I don't know of any current UK suppliers. Mine came from GTS Chris a long time ago.
Another USA option is TCS:
https://www.tcsmotorsports.com/collecti ... shroud-kit
Thanks for the reply. I went with the kit from Prime Driven, should be here in a few days..
- Ryan S
- IMOC Moderator
You got a link for that? I need a shroud.
Ryan S wrote:You got a link for that? I need a shroud.
https://primedriven.com/collections/int ... -kit-parts
Make your own using the oem shroud as a template. That's what I did:thumleft:
I've an intercooler shroud, unfitted at the moment so if anyone needs a template drawing up id be happy to trace it and post either the sketch here or post the thing out.
Lemme know boys.
Lemme know boys.
- Ryan S
- IMOC Moderator
l1ca wrote:I've an intercooler shroud, unfitted at the moment so if anyone needs a template drawing up id be happy to trace it and post either the sketch here or post the thing out.
Lemme know boys.
that'd be great mate! I could knock one up if i know the dimensions, where the tabs for mounting are etc!
Lemme know boys.
did you ever get the dimensions? if so where can i get them
