Oil Sump Pan Fitting
diveboy
Post by diveboy »
First off will a 1991 Rev one oil sump pan fit a 1996 Rev 4 (looks the same)?
If it does do you need to remove the exhaust or will it just slip out?
Got my eye on a second hand one but it will probably knacker the exhaust if I have to take it off.
SonicSW20
Re: Oil Sump Pan Fitting
Post by SonicSW20 »
The sumps are different. Rev1/2 (Gen2 3SGE / 3SGTE) are a one piece design, Rev3+ (Gen3 3SGE/3SGTE) are a two piece design with an aluminium upper piece and steel lower.
I don't know if they can be swapped over though.
diveboy
Post by diveboy »
Impossible to find REV4 one at a good price :-(
pbmr2
Post by pbmr2 »
rev 3 and 5 are the same also, so that might make it easier to find. Also the same 3sge is used in the celica 202.
