[Mk2] [Turbo] Alternative crank shaft pulley? - Aircon removed
sir chad
Post by sir chad »
Has anyone found an alternative crankshaft pulley from a different Toyota?
I have the harmonic damping one with 2 pulleys, but have deleted my Aircon so only need a single pulley.
Engine is out of car, I'm having a nightmare getting the pulley bolt undone and might damage the pulley removing it, if a 3/4 inch beaker doesn't shift it I might have to use heat or a grinder.
SonicSW20
Re: [Mk2] [Turbo] Alternative crank shaft pulley? - Aircon removed
Post by SonicSW20 »
There is no alternative OEM one. Non air con cars used the same pulley.
sir chad
Post by sir chad »
I was wondering if Celicas used a similar pulley
markstevieandmads
Post by markstevieandmads »
Why change it if toyota intended for that one to be there with air con or not?
SonicSW20
Post by SonicSW20 »
Celica pulley is different:
Is your pulley damaged?
