Hi all,
I've just started the grueling task of doing the valve clearances on my rebuilt head. I've got 7 out of 8 all within 0.15-0.25 on the inlet, with the one out of tolerance at 0.09...
I'm going to do the exhaust side tonight. I'm hoping that I have the same issue on the exhaust side, so I can simply swap the shims over to bring them into tolerance.
0.09mm really is not enough gap is it?
Valve Clearances
- Lauren
- Premium Member
Re: Valve Clearances
Do them to the correct tolerance. Yes you can swop the shims around. A bit easier to have a spare set marked up though.
2020 GR Yaris - Circuit Pack
Lauren wrote:Do them to the correct tolerance. Yes you can swop the shims around. A bit easier to have a spare set marked up though.
Speaking of which, I think you still have my spares. Any chance you can bring them to Blyton this weekend?
- Lauren
- Premium Member
Mark said he kind of remembers having something. But he thinks they went to someone else. Mark will have a look as really they are no use to us if we do actually have them. So yes, if we have them happy to return them. I really don't remember. We had that old engine off you, Tom did all the work in rebuilding it. I can't remember/don't know whether we went through a mix of the three heads or so we had lying around and corresponding shims to get the clearances for my rebuilt engine. I know Tom measured them all and marked them all up.
Will see what Mark can find.
I've had a cam cap bolt snap inside the head now!
It snapped when removing it strangely!
I've got 5mm sticking out of the top and do not want to weld a nut onto it to cause distortion to the head.
Aside from drilling out, any ideas?
