[Mk2] [Turbo] Should I Remove My EBC
platmatt8
Post by platmatt8 »
I’m looking at putting the car back to stock/OEM+ and I’m considering removing my Blitz EBC.
The reasons are although ive got a decat still fitted I’ve removed my exhaust and gone back to stock.
I’ve not driven the car in 4 years and forgot the settings and how to set it up.
I’m not a boy racer anymore.
Am I wrong?
SonicSW20
Re: [Mk2] [Turbo] Should I Remove My EBC
Post by SonicSW20 »
Keep it, but set it up on a conservative setting on low (14-15psi), and ~17psi on high. Best of both worlds then.
platmatt8
Post by platmatt8 »
Maybe, I used to hate it on a cold morning when it would hit the fuel cut even with a defender in there.
Electrical / electronic setup hasn’t been a strong point of mine :oops:
chrismit
Post by chrismit »
Alternatively just turn it down to 0 and it will function at your wastegate spring pressure and you just have a free boost gauge
platmatt8
Post by platmatt8 »
chrismit wrote:Alternatively just turn it down to 0 and it will function at your wastegate spring pressure and you just have a free boost gauge
What is that typically on a ct26?
SonicSW20
Post by SonicSW20 »
7-8psi assuming stock actuator.
platmatt8
Post by platmatt8 »
0.5bar :thumleft:
platmatt8
Post by platmatt8 »
Just to confirm I'm not removing it.. WHAT WAS I THINKING!
raptor95GTS
Post by raptor95GTS »
platmatt8 wrote:Just to confirm I'm not removing it.. WHAT WAS I THINKING!
good man! :thumleft:
CalMac
Post by CalMac »
I've just set up my Blitz Dual SBC again with some advice from Gazza - it was really a lot simpler than I thought!
This helped http://www.mediatects.de/files/Blitz_DUAL_SBC.pdf
platmatt8
Post by platmatt8 »
Ye I`ve already got this manual and another (colour version).
Funnily enough I knew about he gain function but had forgotten im going to check it when I get in the car later.
