Rev 3 turbo a/c pulley removal
danjama
Post by danjama »
I have traced a rattle thats been annoying me to the a/c pulley. Its loose. I'd like to just remove the pulley, as the car has never had a/c or even a belt on it since i've had it. Is it as simple as removing the centre nut on the pulley and it will drop off? The only stupid question is the one you don't ask right? :clown:
pbmr2
Re: Rev 3 turbo a/c pulley removal
Post by pbmr2 »
why not just take the whole pump off?
danjama
Post by danjama »
Because that's more unnecessary work.
yokomomr4bx
Post by yokomomr4bx »
Must say, I think given the space you have there and the fact that you don't want to retain function...definitely simpler in the long run to remove the pump and the front condenser rad. You would probably spend as long pulling the pulley off as you would just unbolting the lot and dropping it down.
As it's a clutched pulley I can't see it just falling off once you've removed the faceplate bolts.
danjama
Post by danjama »
Ok i'll jack it up and have a good look, can't be too difficult to remove the pump itself. The pulley is seriously loose though, hence why i thought it'd be easier to just remove that!
SonicSW20
Post by SonicSW20 »
Lol, didn't read OP properly.
Are you sure it's the AC pulley, not the AC *tensioner* pulley?
danjama
Post by danjama »
No i'm not sure :lol: it was a large pulley wobbling about.
SonicSW20
Post by SonicSW20 »
Large pulley will be the AC pulley. The smaller one is the tensioner.
As others have said, I don't know if you can easily remove the pulley on it's own! Only one way to find out.
danjama
Post by danjama »
Ok so unfortunately the pulley just turns with the nut, and I can't see a way of locking it in place to turn the nut independently. Is there a guide on removing the whole pump? I can't have this loose pulley rattling away anymore its getting on my nerves. :D
