[Mk2] [Turbo] Using Aircon pipework for water intercooler.
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Modifications
Author Message
sir chad
PostPosted: Sun Mar 11, 2018 2:12 pm    Post subject: [Mk2] [Turbo] Using Aircon pipework for water intercooler. Reply with quote Reply with quote including images
After fitting a bigger intercooler and deleting my Aircon it occurred to me that I could have used the aircon pipework and matrix as the basis for a water to air intercooler.
Has anyone done this??
Back to top
User is offline
rev2rich
Premium Member
1991 Toyota MR2 Mk2 Turbo Rev2
PostPosted: Sun Mar 11, 2018 4:14 pm    Post subject: Reply with quote Reply with quote including images
Not sure if any one has done it but when I was looking to do my build I found this
https://killerchiller.com/products/universal-parallel-kit
Using the AC to cool a CC set up to keep the wait down. I was unable to do it as my AC was shot so never went this rooot
Hope this helps Rich
Back to top
User is offline
shinny
Premium Member
PostPosted: Sun Mar 11, 2018 11:24 pm    Post subject: Reply with quote Reply with quote including images
Stock aircon condensors tend to be shot by now anyway, but even a new one is probably not going to do as cool a job as a purpose built charge cooler pre rad. There's also other parts of the aircon system that you'd want to by-pass (evaporator, heat exchanger etc) so it's not as simple as hooking up the core / pump to the aircon lines in engine bay and calling it quits.
You're doing a charge cooler for performance reasons, so do it right or you may as well stick with a SMIC.
Back to top
User is offline
pbmr2
Premium Member
PostPosted: Mon Mar 12, 2018 11:23 pm    Post subject: Reply with quote Reply with quote including images
using the lines under the chassis to carry the water to the front isn't a bad shout. Main downside is the pipe is narrow so flow is going to suffer.
The larger the hose the more water there is in the system, you're using the water as a heat sink so more is better.
Proper pre-rad and a decent pump really make or break any CC system. The hose is cheap, very cheap.
Back to top
User is offline
markstevieandmads
PostPosted: Tue Mar 13, 2018 7:46 pm    Post subject: Reply with quote Reply with quote including images
I didnt use the air con pipework mainly because it looked just to small to me.
Back to top
User is offline
pbmr2
Premium Member
PostPosted: Wed Mar 28, 2018 3:39 pm    Post subject: Reply with quote Reply with quote including images
It is tiny, and some of the bends are sharp. Maybe 4-5mm ID, when the 19mm CC hoses are deemed the smaller end of the market.
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Modifications All times are GMT
Page 1 of 1
Jump to:
