[Mk2] [NA] New quiet exhaust?
Andy Champ
Post by Andy Champ »
After 18 years my exhaust is on the way out. Annoyingly it's corroding away on the joint between the cat and the rear box - so I probably have to replace them both - if not now, then fairly soon. It'll definitely fail it's MOT at the end of the month as it is.
I can get a Mongoose system no problem. Original Toyota is silly money. But are there any easily available that are quiet? I'm past the bot racer stage. Heck. my _kids_ are past the boy racer stage...
mr2garageswindon
Re: [Mk2] [NA] New quiet exhaust?
Post by mr2garageswindon »
I've had a few repaired at a local exhaust fabricator when they have corroded between cat and rear box.
If the rest of it looks pretty healthy a repair would work out cheaper or look about for a used unit in better condition.
I think the repair was around £85.
