Cracked cylinder 3 ring land
Goto page 1, 2  Next
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo
Author Message
Sbsoulby
Premium Member
PostPosted: Wed Sep 13, 2017 11:15 am    Post subject: Cracked cylinder 3 ring land Reply with quote Reply with quote including images
Anyone had a similar issue?
Looks like an engine out rebuild time, I'm just pondering wether it's worth doing, it's a rev 3 turbo, in decent shape, minimal rust etc so I guess it's a car to stay on the road, just trying to justify the expense
Back to top
User is offline
Gazza_DJ
Premium Member
1997 Toyota MR2 Mk2 NA Rev4
PostPosted: Wed Sep 13, 2017 11:41 am    Post subject: Reply with quote Reply with quote including images
Running more than standard power I assume?
It's a known weak spot. Good excuse to drop some forged pistons in.
Back to top
User is offline
Sbsoulby
Premium Member
PostPosted: Wed Sep 13, 2017 11:44 am    Post subject: Reply with quote Reply with quote including images
Actually not, it's all standard, never looked to have more power through it, seems strange it's gone, the engine only has 72.000 miles on it
I had a knock issue so I assume that's when it's happened, the car at the moment has a lumpy idle bit like a Subaru so did a leak test and yep, leaking
What forged pistons are available that people are running?
Back to top
User is offline
shinny
PostPosted: Wed Sep 13, 2017 2:01 pm    Post subject: Reply with quote Reply with quote including images
Some get lucky... some don't... some bring it on themselves.
Sorry to hear about the ringland though. I've been through that pain myself [Sad]
Back to top
User is offline
Gazza_DJ
Premium Member
PostPosted: Wed Sep 13, 2017 2:46 pm    Post subject: Reply with quote Reply with quote including images
Did you get to the bottom of the knock issue? That may have caused the ringland to fail.
Back to top
User is offline
Sbsoulby
Premium Member
PostPosted: Wed Sep 13, 2017 2:50 pm    Post subject: Reply with quote Reply with quote including images
I changed the knock sensor and reset it, checked the timing and changed the ignition, I didn't drive it too hard for a while to see if the sensor would go or if the code came back, it didn't so I guessed it was just a one off occurance
Back to top
User is offline
androo007
PostPosted: Wed Sep 13, 2017 3:59 pm    Post subject: Reply with quote Reply with quote including images
As above... usually stock engines never let go on standard boost -not ringlands anyway. Must have some serious knock. You really will need to monitor that.
Wossner 8.0:1 for me [thumleft]
Get the block checked out, hopefully just a light hone. if you can use 86mm pistons dont do larger tha 0.5mm overbore.
Back to top
User is offline
Dale_V
PostPosted: Wed Sep 13, 2017 4:14 pm    Post subject: Reply with quote Reply with quote including images
95 octane? or 97-99 as recomended?
10deg timing?
Back to top
User is offline
Sbsoulby
Premium Member
PostPosted: Wed Sep 13, 2017 4:57 pm    Post subject: Reply with quote Reply with quote including images
99 as standard while I've owned it and yeah the timing was checked once the new sensor was put in, 10 degrees
Back to top
User is offline
pbmr2
Premium Member
PostPosted: Thu Sep 14, 2017 1:04 pm    Post subject: Reply with quote Reply with quote including images
it really is worth having this repaired. the value of a broken engine or a car with a broken engine is much lower so destroying a car due to a broken piston seems mad.
if having to fix it puts you off owning then, after fixing it, you could sell for decent money. breaking it for parts would be a crying shame and prob not make the money you hope.
The engine is going to have to come out, if you can't so the work then take it to an MR2 garage as other lesser garages will charge for their time working out what the specialist already knows.
Good luck!
Back to top
User is online now
Sbsoulby
Premium Member
PostPosted: Sat Sep 16, 2017 10:31 pm    Post subject: Reply with quote Reply with quote including images
So here is my list:
Wiseco Forged Piston Kit - 450.74 + VAT
ARP Head Stud Kit - 140 + VAT
Genuine Toyota Full Engine Gasket Kit - 159.71 + VAT
Genuine Toyota Timing Belt - 39.56 + VAT
Clutch Choices;
ACT Uprated Standard up to 390ftlb - 364.85 + VAT
ACT Heavy Duty 500ftlb - 395.58 + VAT
Competition Clutch Stage 3 - 257.92 + VAT (My Recommendation with a Genuine bearing 21.95 + VAT quoted 450bhp holding)
AEM 320LPH Fuel Pump - 73.33 + VAT
AEM Adjustable FPR Kit - 125 + VAT
Racer X Top Feed Fuel Rail - 153.45 + VAT
820cc DW Injector Kit - 261.03 + VAT
ACL Race Bearings if required Big End 38.73 + VAT, Mains - 40.62 + VAT
Water pump
might leave the injector kit off at the moment until I can buy turbo and ecu, need to do more work on the suspension and brake before I up the power to much
Anything else i should be looking at, obviously filters will be changed
Back to top
User is offline
markstevieandmads
PostPosted: Sun Sep 17, 2017 6:18 am    Post subject: Reply with quote Reply with quote including images
Oil pump?
Where you getting quoted for the full toyota oem gasket kit? Also is there a hg on that list?
I am at a similar point with engine out only difference being mine was running fine but had a stripped thread on the exhaust so removed everything to get to it and replace some old seals.
Wasnt going to go forged either but may look at that as time goes on.
Back to top
User is offline
Sbsoulby
Premium Member
PostPosted: Sun Sep 17, 2017 7:50 am    Post subject: Reply with quote Reply with quote including images
All them prices are from Paul at tcb and that gasket kit includes the headgasket, seemed pretty cheap but he told me it was genuine Toyota
I think if your engine is out etc, for the little extra I think it's worth buying the forged stuff, bit of future proofing yourself if you did want to up power
Back to top
User is offline
markstevieandmads
PostPosted: Sun Sep 17, 2017 7:57 am    Post subject: Reply with quote Reply with quote including images
Strange ...i asked paul a few weeks ago for a gasket kit and he said he didnt have any and didnt know when he was getting them in.
Also he gasket kit i needed was for rev 2 turbo and he said i had to buy the rev 3 hg seperate for an extra 50 or whatever it was.
Glad hes got them now then so its an option.
Back to top
User is offline
androo007
PostPosted: Sun Sep 17, 2017 6:21 pm    Post subject: Reply with quote Reply with quote including images
Do the clutch once, HD. I like mine. What compression ratio are you thinking about?
Back to top
User is offline
Gazza_DJ
Premium Member
PostPosted: Sun Sep 17, 2017 7:06 pm    Post subject: Reply with quote Reply with quote including images
Consider grabbing replacement timing belt tensioner and idler bearings, and hydraulic tensioner. May not be needed but at least you know it's all good there. The belts themselves rarely fail of their own accord, it's usually a tension issue, failed tensioner, idler etc that takes the belt out.
Back to top
User is offline
Sbsoulby
Premium Member
PostPosted: Tue Sep 19, 2017 4:54 pm    Post subject: Reply with quote Reply with quote including images
Yeah they are all good ideas, it's all better to do while the engine is out I suppose, yvs are doing all the work so I'm leaving most of the technical parts to him
Back to top
User is offline
Milo_101
Premium Member
PostPosted: Sat Sep 23, 2017 4:37 pm    Post subject: Reply with quote Reply with quote including images
Also, Do not forget to do the coolant hoses under the turbo nicknamed the Hose from Hell, and Hose from Hell on earth [part # 16282-88480] & [16281-88461]
And while you are in there, i'd check the valve clearances. it's more than likely than most of your valves will be out of spec by now. Good idea to re-shim them. It's a slippery slope though, cause you'll want to to a leakdown test and maybe re-seat the valves by hand lapping them. I found all but one of mine were not sealing tight anymore. definitely recommended, but entirely up to you.
Might want to also do the idler pullies as suggested and definitely do a New tensioner for the belt.
OR just do a gen 4 swap [Laughing] and rebuild this engine slowly.
GOod luck!
Back to top
User is offline
rev2rich
Premium Member
1991 Toyota MR2 Mk2 Turbo Rev2
PostPosted: Sat Sep 23, 2017 5:19 pm    Post subject: Reply with quote Reply with quote including images
I do have a set of 1000 miles wossner forge pistons if your intrested 86.5 mm iirc ..........
Back to top
User is offline
Sbsoulby
Premium Member
PostPosted: Wed Sep 27, 2017 2:51 pm    Post subject: Reply with quote Reply with quote including images
Ok cheers, I'll look into it all thanks,
I'm not keen on wossner pistons. Tcb put me off buying them and preferred the wiseco, also I'm hoping to stick to 86mm or as close to but thanks for
The offer
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
