[Mk2] [Turbo] Rev1 Turbo - Would I need a capicitor?
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> ICE and Security
Author Message
IMR2T
PostPosted: Thu May 07, 2015 9:12 pm    Post subject: [Mk2] [Turbo] Rev1 Turbo - Would I need a capicitor? Reply with quote Reply with quote including images
I'm replacing all the speakers with components and was aiming to run them off a 5-600watt 4ch amp along with the sub(or a new sub).
I've noticed when I put the window down there's a small drop in revs tempoarily.
I know nothing wiring an amp etc but I'm keen to learn.
With regard to the car being 25yrs old would I nd a capacitor or will the altenator etc be ok?
Back to top
User is offline
thomp1983
PostPosted: Thu May 07, 2015 9:48 pm    Post subject: Reply with quote Reply with quote including images
No system ever needs a power cap There a poor work around for not wiring a system properly.
If you find your getting significant voltage drop with your setup fitted then you need to upgrade the big 3 wires to bigger cables. your 600w amp us probably going to be 300wrns at best the stock wiring should be fine with it.
Back to top
User is offline
IMR2T
PostPosted: Thu May 07, 2015 9:58 pm    Post subject: Reply with quote Reply with quote including images
Interesting.
Sorted. Good to know [thumleft]
I haven't bought an amp yet, what are the 3 big wires?
Back to top
User is offline
thomp1983
PostPosted: Thu May 07, 2015 10:36 pm    Post subject: Reply with quote Reply with quote including images
There battery negative to chassis, engine earth to chassis and battery positive to alternator, they want to be a minimum of 4awg cable 0awg is preferable, welding earth wire is a cheap alternative just add extra runs alongside the factory cables
Back to top
User is offline
IMR2T
PostPosted: Fri May 08, 2015 8:09 am    Post subject: Reply with quote Reply with quote including images
Sorted, thanks for that mate [thumleft]
Back to top
User is offline
madbasshunter
1991 Toyota MR2
PostPosted: Mon Jul 20, 2015 1:45 pm    Post subject: Reply with quote Reply with quote including images
I cheated and instead of running an extra cable from alternator to battery I used the battery to starter cable Toyota fitted. So went from alternator to starter with 0gauge
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> ICE and Security All times are GMT
Page 1 of 1
Jump to:
