[All] [Generic] Group Buy - Meister R Coilovers.
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> Group Buys - MR2 related
Author Message
MeisterR
PostPosted: Thu Feb 12, 2015 3:06 pm    Post subject: Reply with quote Reply with quote including images
mr2magic wrote:
Thanks! Do I just wait or is there something I should fill out?
Just wait for further update on when our shipment is due to arrive.
Edwin
Back to top
User is offline
ggpippas
PostPosted: Thu Feb 19, 2015 8:52 am    Post subject: Reply with quote Reply with quote including images
Hi all you may remember me as the person from page 3 who ordered a set of MeisterR's back in Oct 13 and ive been happy with them ever since.
I had the car corner weighted and because of the weight balance of an MR2 the optimum height is essentially set at stock. The additional height also allows the damper to go through its full range of movement.
In terms of comfort they are excellent. You can barely tell the difference between stock and these. Road handling is significantly improved over stock. Also they get better after a couple of months as they start to free up and settle.
On the track they are also very good but if you really want a track monster with slicks then the these are possibly too soft. You can set the damper to its maximum hardness to reduce body roll but at this point the spring felt out of its optimum performance range. My track preference was around the 23 to 25 clicks mark using semi-slick road legal tyres. I found that you need that bit of body roll to get good heat into the tyres. I also run different damping front to rear.
Personally I made a spreadsheet noting down the number of clicks and then just going for a drive and writing down what i felt. The difference between max soft and max hard is huge so most people should be able to find something that they like. Also they way the front to rear hardness affects the handling is very interesting.
Some people might think they want the hardest spring and damper going without slicks you overload the tyres and they will overheat.
With the MeisterR i found they were a very good all rounder for the road and track.
As for aesthetics i couldnt care less. I havent looked recently but i dont think mine are flaking. As for the locking nuts seizing this is common to every coilover. Just ask anyone who runs coilovers from any company. Do i care? No. The car has been corner weighted. I have no intention of changing the ride height.
I think thats everything i can think of for now.
Back to top
User is offline
shane34
PostPosted: Sun Mar 08, 2015 10:58 pm    Post subject: Reply with quote Reply with quote including images
Got these on my car now.
I had bc coilovers before. Last turbo. I can say these feel alot better then them. I also i paid 850 for the bc, the only difference was they had rear pillow ball top mounts. Which are probably a waste for my driving.
This would be my 1st mod if i was to ever own a different mr2. This is road use btw, not track.
Great shocks easy to adjust. I could rotate the main thead by hand when i was lowering them. No need for the spanner only to lock. Would say they seem lighter then oem. Without scales tho, so dont quote me on this.
Back to top
User is offline
ashley
PostPosted: Mon Mar 09, 2015 1:11 pm    Post subject: Reply with quote Reply with quote including images
You alter the ride height by moving the lower srping platform, so this should have zero effect on the range of available damper movement- unless I misunderstand?
Back to top
User is offline
C35Rob
1996 Toyota MR2 Mk2 Turbo Rev3
PostPosted: Mon Mar 09, 2015 4:52 pm    Post subject: Reply with quote Reply with quote including images
the height is adjusted by winding the threaded damper body into the lower cup, the spring should be set up with zero preload, i.e the lower platform just nipped up to hold the spring in place.
altering the ride height via the spring perch will obviously effect spring preload/damper droop
although I'm pretty sure that's the point you were making too?
Back to top
User is offline
bigdave247
PostPosted: Tue Mar 10, 2015 3:35 pm    Post subject: Reply with quote Reply with quote including images
hi all just a quick question, is the kit supposed to come with four drop links as my kit only came with two cheers dave [Smile]
Back to top
User is offline
shane34
PostPosted: Wed Mar 11, 2015 6:37 pm    Post subject: Reply with quote Reply with quote including images
they come with two new fronts, reuse the rears.
Back to top
User is offline
bigdave247
PostPosted: Wed Mar 11, 2015 8:28 pm    Post subject: Reply with quote Reply with quote including images
Ok cheers [Smile]
Back to top
User is offline
fred130111
1992 Toyota MR2 Mk2 NA Rev2
PostPosted: Fri Mar 20, 2015 9:28 am    Post subject: Reply with quote Reply with quote including images
I am very interested in this.
However what are they like on the hardest setting? I don't really care about crashy ride etc just want something that can be set firm with very little body roll.
Also how much do they lower by maximum?
Back to top
User is offline
wenguin
PostPosted: Sat Mar 28, 2015 7:03 pm    Post subject: Reply with quote Reply with quote including images
I'm interested in these as an alternative to buying OEM KYB struts, top mounts and drop links.
My only issue is that I'm worried they won't fit without spacers with my new wheels, can anyone shed some light/experience?
Wheels are 17", 8J front and 9J rear with ET35 front and ET38 rear offsets. I don't have tyres for them yet, but was planning on 215/40 and 235/40.
Back to top
User is offline
mr2magic
1991 Toyota MR2 Mk2 Turbo Rev1
PostPosted: Tue Apr 07, 2015 9:57 am    Post subject: Reply with quote Reply with quote including images
Hey Edwin,
any news on how far along the new production run is?
Back to top
User is offline
MeisterR
PostPosted: Wed Apr 08, 2015 2:33 pm    Post subject: Reply with quote Reply with quote including images
mr2magic wrote:
Hey Edwin,
Hi Guys,
I did chase the production before the holidays and it has taken longer than expected but we have an approximate time of end of May. Thanks for your patience.
However some people on the list have not taken up the offer and I think we have given enough time for them to purchase. So those who want to purchase now we still have a few sets in stock ready for delivery.
Edwin
Back to top
User is offline
OwenK
1994 Toyota MR2 Mk2 NA Rev3
PostPosted: Thu Apr 30, 2015 11:23 am    Post subject: Reply with quote Reply with quote including images
I want a set! Edwin, PMd you. How soon can I get them?
Back to top
User is offline
MeisterR
PostPosted: Tue May 12, 2015 4:17 pm    Post subject: Reply with quote Reply with quote including images
This offer is still running and coilovers are in stock.
Edwin
Back to top
User is offline
mr2magic
PostPosted: Tue May 12, 2015 5:02 pm    Post subject: Reply with quote Reply with quote including images
Fantastic!! How do we order and pay again? [Laughing]
Back to top
User is offline
MeisterR
PostPosted: Wed May 13, 2015 10:32 am    Post subject: Reply with quote Reply with quote including images
Hi,
2 people in the top 9 of the list didn't place their order. We have assumed they decided not to go ahead as there has been a reasonable of time.
So we still have 2 sets in stock for this offer which you can use the 20% discount code IMOCGB20 place your order here http://www.cyberspeeds.com/index.php?main_page=product_info&cPath=81_138&products_id=317
Edwin
Back to top
User is offline
mr2magic
PostPosted: Thu May 14, 2015 10:21 am    Post subject: Reply with quote Reply with quote including images
Hi Edwin. Thanks for the info [Smile]
Sorry to sound like a dick but is there any way to pay without having to pay to be able to pay? (Surcharge for credit cards) [Wink]
Back to top
User is offline
MeisterR
PostPosted: Thu May 14, 2015 3:08 pm    Post subject: Reply with quote Reply with quote including images
That is the card fee, only way to avoid it is to use your debit card.
Edwin
Back to top
User is offline
mr2magic
PostPosted: Thu May 14, 2015 6:51 pm    Post subject: Reply with quote Reply with quote including images
Damn....I'm in Germany and my debit card isn't accepted [Sad]
Nevermind....I'll just have to pay extra then.
Back to top
User is offline
MeisterR
PostPosted: Fri May 15, 2015 9:37 am    Post subject: Reply with quote Reply with quote including images
I'll drop you a PM.
Edwin
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> Group Buys - MR2 related All times are GMT
Page 7 of 8
Jump to:
