Evans Coolant Power Cool 180 - Group Buy #1
Forum For IMOC Group Buys
CarBen Fibre Creations
Post by CarBen Fibre Creations »
Would anyone be interested in Evans Coolants, these coolants are proven to work better in high performance cars. Information below:
POWER COOL 180°
Waterless Coolant for:
High performance cars
Boiling Point:
Above 180°C
Antifreeze Properties:
Protects below -40°C
Benefits:
Improves Combustion, Maximizes BHP, Prevents Boil-Over
Corrosive Properties:
Eliminates corrosion and erosion
Life Span:
Protects for life
Toxicity:
Non-Toxic
Power Cool 180° is a waterless engine coolants formualted for all types of motorsport. The unique properties of Evans have been embraced by professional racing teams
No Water Means...
No Overheating
Power Cool 180 has a boiling point of 180°C and will not boilover.
More BHP
Power Cool 180 eliminates premature detonation associated with overheating.
No Corrosion
Water contains oxygen, oxygen allows corrosion. Power Cool 180 eliminates corrosion.
No Pressure
Power Cool 180 allows your cooling system to run at a lower pressure, reducing the strain on engine components.
No Liner Pitting
Power Cool 180 generates significantly less pitting when compared with all water based coolants.
The Science Behind Evans
No Overheating
Traditional water based coolants regularly cross the thermal boundary that separates Efficient Nucleate Boiling (A) from Inefficient Critical Heat Flux. CHF leads to localised film boiling (B) and steam bubbles circulating throughout the cooling system, which often results in overheating and combustion issues. Evans Waterless Coolants boil above 180º C ensuring effective cooling and efficient fuel burn is maintained for all engine loads and ambient air temperatures.
More BHP
When water-based coolants vapourise adjacent to the combustion zone, hot-spots are formed. These hot-spots have been proven to cause pre-ignition in petrol engines and detonation issues in diesel engines. Evans Waterless Coolants eliminates hot-spots and subsequently improve combustion efficiency and increase power delivery.
No Corrosion
Water is the root cause of corrosion in all cooling systems, via oxidation (rusting) and galvanic (electrolytic) action. Evans coolants do not contain dissolved oxygen and have a much lower conductivity (increased resistivity) compared with water-based coolants. Subsequently replacing water with Evans non-aqueous solution eliminates corrosion and the need to periodically refresh or replenish the coolant.
No Pressure
Water requires additional (cap) pressure to prevent it boiling within the engine. This additional pressure can vary between 7psi and 29psi (0.5 Bar to 2 Bar) which places significant stress on cooling system components, including hoses, gaskets and radiators. Evans Waterless Coolants generate much lower pressures, in the region of 4psi, and therefore reduces strain on all components.
No Liner Pitting
Liner pitting is primarily caused by the rapid formation and collapse of small steam bubbles on the metal surface. Over several years this process can lead to severe surface erosion and deep liner pitting. Evans Waterless Coolants are not prone to forming vapour bubbles and proven, by SAE trials, to virtually eliminate surface erosion and pitting.
RRP for the coolant is:
25 Ltr - £299.75
5 Ltr - £64.95
2 Ltr - £29.95
Group Buy Prices:
1-5 = 5%
25 Ltr - £299.75 = £284.77
5 Ltr - £64.95 = £61.71
2 Ltr - £29.95 = £28.46
5-10 = 10%
25 Ltr - £299.75 = £269.78
5 Ltr - £64.95 = £58.46
2 Ltr - £29.95 = £26.96
10+ = 15%
25 Ltr - £299.75 = £254.79
5 Ltr - £64.95 = £55.21
2 Ltr - £29.95 = £25.46
Prep Fluid
RRP:
5Ltr - £39.95
2Ltr - £15.99
Prices will be 10% off any Prep Fluid
Plus £12.50 shipping to any UK address.
How to change to Evans Coolant
You simply do two coolant changes. Drop out the current water based coolant, fill the system three quarters full (minimum) of Prep Fluid, run it up to temperature for around 25 minutes to allow the thermostat to open up and turn the heater on to let the Prep fluid into the heater matrix, the Prep will then absorb the water based coolant that remained after initial drainage. Drop the Prep fluid out and keep it in a sealed container as it can be used again, three times in total before it loses its hygroscopic capabilities. If you are going to use it again, filter it through a cloth or an old pair of tights as it will also extract any lose gunk or scale that has previously built up over time. Fill up with the new coolant.
If you are interested add your name to the list below in this format please, I have this group buy over a lot of forums so need to keep track of who is where.
Name / Coolant Amount / Forum Name
Thanks guys
Ben
www.carbenfibrecreations.co.uk
Last edited by CarBen Fibre Creations on Tue Jun 11, 2013 3:29 pm, edited 1 time in total.
Peter Gidden
Re: Evans Coolant Power Cool 180 - Group Buy #1
Post by Peter Gidden »
Careful. IIRC, some of the Evans products need draining during winter months or long periods of inactivity as it gels.
dawesy
Post by dawesy »
i run this peter and have not had any problems during winter (car lives outside :( )
however it is vitally important that all traces of water are removed from the system before using (evans do a prep fluid for this)
it does stink though if spilled on the engine and doesnt evaporate making leaks easier to see.
good heads up though
As dawesy says it doesnt need to be flushed out and it doesnt gel over, there was a fluid released a few years ago that was like that but it has nothing to do with Evans :)
Yes the prep fluid is £15.99 for 2ltr, can be used up to 3 times but once this coolant is in you should never need to change or add to it.
SuperRedMR2
Post by SuperRedMR2 »
Do you not have to have a different radiator or water pump for this?
MR2 Rich
Post by MR2 Rich »
SuperRedMR2 wrote:Do you not have to have a different radiator or water pump for this?
Nope. :thumleft:
No 2 :(
GeorgeL
Post by GeorgeL »
I'm going to keep my eye on this.. I'm very interested
SuperRedMR2
The mk1 takes 10-12 litres of coolant so this could be very expensive even with a discount.
I am sort of interested considering i've just rebuilt my engine and don't want any overheating issues.
seangtir
Post by seangtir »
Id be interested, 25l and 10l prep id be looking for :thumleft:
Return to “Group Buys - MR2 related”
