I am taking names of people interested in a potential group buy of Depo Gauges. I am also running the list on MKIVsupra.net and the MR2OC.
The link to an earlier discussion thread i here:
http://mkivsupra.net/vbb/showthread.php ... ing-Guages!
And the link to the Depo Racing site is here:
http://www.deporacing.com/
Once I get numbers I will then look at getting prices.
Are you interested in a potential GB for Depo Gauges?
Re: Are you interested in a potential GB for Depo Gauges?
1. CJ - AFR, Boost, Oil Pressure (52mm)
2. Hellstrom - Oil pressure, Oil temp, Boost, (60mm).
3. Westy882 - 60mm EGT, oil temp, water temp, voltage 4 in 1, 52mm boost with peak hold, 52mm oil pressure with peak hold
1. CJ - Boost, Oil Pressure, Oil Temp (52mm)
2. Hellstrom - Oil pressure, Oil temp, Boost, Innovate afr gauge (60mm).
4. p3te - 60mm boost, oil pressure, oil temp and water temp[
5. MartinR - oil temp, oil pressure (60mm)
In what price range are these?
MMaddict wrote:In what price range are these?
It depends on the gauge but approximately about £60 or so normal retail.
To be honest, due to a lack of response, I cannot see this going forward as the numbers wont really justify a huge discount from the seller.
Might be the Lack of regular Retail prices and pictures
MMaddict wrote:Might be the Lack of regular Retail prices and pictures
Ah right.
I stupidly assumed that a link to the Depo site showing all the gauges and the link to the Supra site showing opinions and prices but have sufficed.
