Would a Rev 3 gutted Cat past MOT?
Re: Would a Rev 3 gutted Cat past MOT?
Mine did last week.
http://www.vosa.gov.uk/vosa/publication ... 1dd9f62283
Print this page and take it with you to MOT. Helps if you let the tester know about the exempt status.
HTH
HTH
Will-Turbo wrote:Question as Subject???
if you have an M plate or older yes, N plate or younger no
how do you work that out?? If the engine is in vgc the sensor wont detect the lack of a cat - and if it fails just lean it out for the test (then return to standard). Easy!
fizzy. wrote:how do you work that out?? If the engine is in vgc the sensor wont detect the lack of a cat - and if it fails just lean it out for the test (then return to standard). Easy!
Yeah well sadly the limits for the CAT test are very low and most cars in vgc will still fail.
Still what's life without a challenge
