All - anyone know what the 2 gasket part numbers are that are required for a cat on a Rev-1 Turbo ?
The top one hae 5 stud holes in it and the bottom one has 3 stud holes in it.
Regards - Gav.
Cat gasket part numbers - Turbo...
cat gasket part numbers
If your talking about the ones you would replace when fitting a downpipe, then they are:
Turbine outlet gasket: 17279-88381
o2 sensor gasket: 17166-88381.
Hope that helps you out,
cheers,
Michael.
cheers,
Michael.
