HYDRA NEMESIS EMS
The Hydra Nemesis combines the power and flexibility required by modern day vehicles whilst adding advanced functions such as Closed Loop Knock Control, Auto tune (Wide band Option required), Antilag and Launch control all in a single affordable package.
The Hydra ECU offers many advanced functions not seen on other ECUs in this category, some of the key features are listed below
8 Sequential Injector (High Current) and Ignition Outputs
32 x 32 High resolution Fuel and Ignition tables
Switchable Fuel and Ignition tables (32 x 32)
16 User Definable PWM Auxiliary Outputs
Internal 3 bar Map Sensor (5 Bar Optional)
Dual Knock Sensor inputs for closed loop control
Dedicated NTK Wide band Lambda input
Dual Closed Loop Narrow band Lambda control
9 Auxiliary inputs
Variable Camshaft Control (up to 4 Cams)
Drive By Wire Throttle (additional cost option)
Antilag
Launch Control
Dedicated outputs for standard Vehicle Instruments
Plug and Play applications for most Japanese vehicles
Hydra Nemesis EMS
With all these features and many more the Hydra Nemesis is one ECU option you can't afford to ignore.
We have these in stock and available to fit the following :
All MR2 SW20 Turbo & NA 1990 >
What you will get is :
Hydra Nemisis ECU
Plug & play Loom
V2.5 Software disc
Comm Lead
Base Map
The price is based on 5 units and is £950 inc vat and delivery to anywhere in the UK
For anyone who would like details on mapping cost please PM me.
This is the exact ECU i run in my own MR2 and cant fault it in anyway
Thanks Steven
Please add your name to the list below if you are intrested.
1.
2.
3.
4.
5.
HYDRA NEMISIS V2.5 stand alone ECU for all SW20 MR2 Turbo & NA
Re: HYDRA NEMISIS V2.5 stand alone ECU for all SW20 MR2 Turbo & NA
Heard nothing but good things about these ecu`s.
Still debating on getting one myself, but i need paint 1st.
platmatt8 wrote:Heard nothing but good things about these ecu`s.
Honestly bud.. they are a excellent piece of kit... the exact ecu i have been running in my own car for 3 years now. It comes complete with all the toys...
as you can see in the spec.
Steven
can they control ITB setup (4d fuel and ignition maps)?
can it control ACIS (NA high comp car here)
can i switch to other fuel and ignition map based on throttle % and revs?
i'm in VERY urgent need of a good ecu, i was leaning toward the link G4 storm wich does all i need for less, but i need to make my own harness for it
can i download the software somewhere to see if this system is what i need?
MR2DIE4 wrote:can they control ITB setup (4d fuel and ignition maps)?
Hi.. you have a PM.
A bit off topic but could you just supply me with a loom for a rev2?
how do you control the antilag and launch control, does it need something like the powerFC commander in the cabin?
platmatt8 wrote:A bit off topic but could you just supply me with a loom for a rev2?
Hi yeah should be able to supply a loom no probs...
PM me for a price.
Thanks Steven
wadeski wrote:how do you control the antilag and launch control, does it need something like the powerFC commander in the cabin?
Hi.. No there is no in cabin commander required.
The Anti-lag is controlled just by a simple on/off switch located where ever you want really, the launch control can be controlled the same way or it can be set up so that it automatically comes on below a certain speed, thats the way my own car is set up, when driving below 15mph the lauch control is on.
Thanks Steven
I'm interested. Currently running mk1.5 with rev 2 management, c20 turbo and MBC(bleed).
I see the loom is 'Plug and Play' would it allow me to get rid of the AFM on the rev 2 engine and just use MAP?
Could the nemesis (with the correct solenoid) be programmed to control boost or would still need an EBC such as Gizzmo MS2?
Not a bad price this
considered doing some sort of payment options on these at all mate!!
aw11rally wrote:I'm interested. Currently running mk1.5 with rev 2 management, c20 turbo and MBC(bleed).
Hi.. Yes this will allow you to remove the AFM on the rev 2 and you can also use it to control boost lots of various ways.
Top piece of kit...
Cheers Steven
Hi is it in a DOS or Windows enviroment ?
clairemr2 wrote:Hi is it in a DOS or Windows enviroment ?
You have a PM...
Are you able to upgrade older Nemesis models to the latest firmware. If so how much ?
How much for a full day of mapping ?
very nice ecu...
are these still for sale in this price?
