Is extreme oil consumption the only give away of a pre-cat failure? When viewing a car what else can I check to determine if the pre-cats are failing and going back into the engine? I cant open up someone elses car and start checking the pre-cats so is there any other way? My current 14 y/o car uses around 100ml per 1000 miles so I wouldn't be surprised if the pre-facelift mk3 uses oil too but how much is too much? I read someone's car was using 400ml per 1100 miles and the forum members said its within limits.
Also this will be my first purchase without help so any advice is greatly appreciated.
The car is high mileage but has full service history.
Thank you.
