Found out what was causing my fuses to blow, the fog light switch. Everytime its on it blows the PWR fuse so my fog lights arnt working... how do i get at the back of the fog lights to get to the loom to test them
Ta
Just so some dont know, the two lights in the main grill :p
Fog light switch
Re: Fog light switch
BLOODUK wrote:Found out what was causing my fuses to blow, the fog light switch. Everytime its on it blows the PWR fuse so my fog lights arnt working... how do i get at the back of the fog lights to get to the loom to test them
Ta
Hiya,
the fog lights are held on with two screws at the top of the foglight. just remove them and pull the fog lights out. You can also see the wiring from underneath the car.
Dude - try keeping your questions in the one thread, it's a nightmare keeping track of your threads!! :P
Paul.
I understand its a pain, but it helps others...... what if someone does FOG LIGHT problem , it might be easier to see the thread name. Thats the only reason ive done it, thanks for the help again though
Is it particularly foggy near you? Im sure as its coming up to summer you wont need to use them anyways!!
